Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #256 (permalink)
Old 09-27-2007, 11:44 AM
mrfixit290 mrfixit290 is offline
mrfixit290 is starting off with a positive reputation.
codes
hello i just bought a 2000 excursion cant find keyless code anywhere could you
send my a copy to mrfixit290@yahoo.com thanks
~mrfixit290
  #257 (permalink)
Old 09-27-2007, 11:47 AM
lightning1968 lightning1968 is offline
lightning1968 is starting off with a positive reputation.
Hi there, I'm still interested in getting a copy of the codes E-mailed to me if possible. Thanks for the help...
Mike
lightning1968@msn.com
  #258 (permalink)
Old 09-30-2007, 09:54 AM
guiri's Avatar
guiri guiri is offline
guiri is starting off with a positive reputation.
Kinda related question. What do you do when your keyfob goes bad or something?
Where do you buy them, how much are they?
Also, since I have a different one myself (aftermarket with remote control) and don't use my original ones, can I reprogram them for him and if so, how do you do that?
Thanks
George
  #259 (permalink)
Old 09-30-2007, 09:31 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
I finally found mine!! It was behind the cd player and after many attempts to locate I finally found the box on the firewall. I could not see it at first because of the cross bar and vent ducts. I finally caught a slight view of a label on a black box. I couldnt actually see it, but with an inspection mirror and some odd manuvering I got the numbers.
Thanks for all the information.
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #260 (permalink)
Old 10-04-2007, 11:57 PM
LionFan's Avatar
LionFan LionFan is offline
LionFan is starting off with a positive reputation.
Hey guys, I just bought a 2005 Excursion 6.0L today and am going crazy trying to find the RAP Module, could someone please send me the list of codes?
kenocko@telus.net
Thanks in advance
__________________
2005 Excursion Limited 6.0L, Hellwig Rear swaybar, Bilsteins and RAS.
If you can't laugh at yourself, you've got no business laughing at others.
  #261 (permalink)
Old 10-13-2007, 07:55 PM
Wren Wren is offline
Wren is starting off with a positive reputation.
Could I please get a copy of the spreadsheet with the possible door combos? I'm trying to get them working on my excursion.
wren.keith -at- gmail.com
Thanks in advance
  #262 (permalink)
Old 10-17-2007, 08:28 PM
gtadim gtadim is offline
gtadim is starting off with a positive reputation.
Quote:
Originally Posted by MattsExcursion
I have a 2000 X, and when I bought it, the owner had no idea of the code. So I looked at article after article... tore apart the WHOLE dash, and looked in all the places... NO CODE... I guess they didn't put printed codes on the '99 SuperDuty and 2000 X.. I wasn't about to pay $100 for some guy to tell me the code, so I looked into it more. I read a forum (not sure where) where someone used Microsoft Word to create a Macro to make all the possible codes... (sounds like something you wouldn't want to do, but you will be surprised) There are 5 buttons on the keypad. So you go into word create this macro that uses all the possible 5 digits numbers it could make with 0 1 2 3 4. It makes about a total of 10 sheets of codes at like 5 or so columns on each page.... TONS OF CODES. You then label the 1/2 key: 0 the 3/4 key: 1 and so on.... so now your keypad looks like 0 1 2 3 4... then you enter codes.... I did this for 10 min. and found my code. Some may be quicker, some may take longer... If anyone would like me to send them this word document with all the numbers, I would be glad too, also if anyone would like me to explain the procedure better I will. I'm so greatful that I found out about this way. I wish I would have remembered who it was so I could give the credit to that person, but it was probably 6 or 8 months ago. Good Luck!
Hi Matt, this is gtadim, I read your post and would like a copy of the information. I bought a 2000 excursion recently and am having the same problem locating the code. Please send info to gtadim@can.rogers.com thanks.
  #263 (permalink)
Old 10-20-2007, 09:25 PM
neumannj1 neumannj1 is offline
neumannj1 is starting off with a positive reputation.
Has anyone found the keypad code location on a 2006 f-150 super crew?
  #264 (permalink)
Old 10-20-2007, 09:47 PM
greagin greagin is offline
greagin is starting off with a positive reputation.
i would also like a copy of the codes if i could get them. email is greagin@wesleycommons.org. thanks!!
__________________
GRANT
2001 F-250 Lariat CC 4x4 HPX, 6637, DP Tuner, AIH Delete, CCV, WW, CCK, Muffler Delete, Stancor GPR with LED, 03 Projector Headlights, bilsteins
2001 Excursion Limited 4x4 HPX, 6637, DP Tuner, AIH Delete, CCV, WW, Banks Big Head W/G, 03 Projector Headlights, bilsteins
  #265 (permalink)
Old 10-21-2007, 02:17 PM
Smile list of codes
Hi, this is gtadim, I cracked the key pad code on my 2000 excursion with the help of all you Ford truckers. Thanks alot the list of codes worked. It takes a little patience but you'll get it. All in all it took me about 2 hours till I found my code. Thanks again,
George.
  #266 (permalink)
Old 10-22-2007, 06:59 PM
n48017 n48017 is offline
n48017 is starting off with a positive reputation.
Hi. Looked every where except up the tail pipe for the code on 01X. Could someone please e-mail me the code list? I changed the batteries in the truck and now the THEFT light is flashing and the truck won't start. It turns over real good though!!!!
Thanks, Glenn blackdiamond@linwoodnet.com
  #267 (permalink)
Old 10-22-2007, 08:09 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Try another key,, Or,, get in close the door then insert the key and try again. Sounds like the anti theft doesn't recognize your key
  #268 (permalink)
Old 10-22-2007, 08:49 PM
HI. I tried both factory keys, as well as various combinations to try and get it running. The THEFT light flashes fast as soon as the ignition is turned on. I'm hoping that entering the key pad code will reset it.
  #269 (permalink)
Old 10-22-2007, 10:03 PM
vettdvr's Avatar
Probably won't.. Try disconnect the battery with the doors unlocked. Also consider locking the door then unlock the door with the key.
Some alarm systems have interesting logic in them. Jim
  #270 (permalink)
Old 10-23-2007, 08:05 AM
Talking
I think I should buy a lotto today. Picked a page of code mid pack. Half way down the first row found the code. Truck still wouldn't start ( THEFT light still flashing fast ). Turned the key to on, rolled the driver window down, hit the lock button, shut the door, then entered the key code. Door opened, the THEFT light went out during glow plug time, truck fired right up. Thanks Guys! Glenn
2001 Excursion 7.3
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
