Hi everyone, new to the forums. I’m considering purchasing a1961 F100 to tow my 1952 travel trailer. Weight is not an issue, trailer is only 2,000 lbs., but I have not owned a unibody. Are there any issues with installing a frame mounted hitch?
Thanks...
When I put one on my 63 It was pretty cut and dry. Mocked the hitch up, drilled, and bolted it in. Everything was easily accessible for the wiring harness as well.
