61-63 Unibodys
#136
Rob
#137
"63 long wheelbase unibody
I am in central Oh, and I have a "63 Long wheelbase unibody p/u, with a 6 cyl. engine. I bought a 4 speed manual overdrive tranny for it to save gas. I was previously driving my F-350 crew cab 4x4 diesel, and it was getting quite expensive after diesel fuel hit around $4.00 a gallon. I am putting new floor pans, cab mounts, and floor supports in it along with new step plates,and backsplash step panels. Also replacing both inner fender splash aprons. (a good bit of money and work, but well worth it in the end.) A little bit of body work, some paint and a new stainless steel bed floor,and she should be good to go. I like my Fords I have this truck and my "99 F-350 4x4 centurion superduty diesel, A '36 Ford pickup (in restoration progress), An 8-N Ford tractor W/a flathead Ford V-8 and a 4 cylinder Ford 8-N.(both tractors have sherman combo overdrive transmissions. All of this keeps me off the streets,and in the barn working.
#138
1962 unibody
Hi, Robert I have a 1962 unibody with 223 six and four speed with granny gear. Thanks,Robert H
#139
#140
#141
The closest truck I have to yours is F10CK361771 made out of the Kansas City plant. It was on auction on Ebay, but not sure when. Is yours a Custom Cab? What do you have listed as a DSO. I have roughly 73, 1963's on my list some with serial numbers and some without. The best would be if they would list the serial number entirely, and give me a shot of the warranty tag. It interesting to see how far some of these trucks have traveled, the DSO number tells the district sales office but it tells so much more, but the information is lost. It would be cool to find out what extras were placed on some of these trucks and figure out Fords Codes on DSO numbers.
#142
#143
C= 292 CID V-8, 2V carb, 135 Hp, 3800 RPM
R= Built at te San Jose Assembly Plant
362037= Built Dec 1962
3 on the tree, they had to types
(A) was Ford 3 Speed Manual Light Duty Transmission,, No Syncro 1st gear
(B) was Borg Warner T-85N 3 Speed Overdrive
The trans code on the warranty tag will tell you which one. What did you have for Axle code? By your avitar the truck appears to be red, if it original color the color code would be (J) Rangoon Red.
#144
Here's my warranty tag info: 14 J F100 66B A 12 5000 146 3800 71
I was surprised by the transmission not having a syncro for first. I'm able to downshift to first without any grind. I must be decent at rev matching, if that's possible.
I bought the truck in southern California, and with all the paperwork I have it seems that's where it pretty much stayed. No Rust!!!
#145
Originally Posted by kjvforme
(A) was Ford 3 Speed Manual Light Duty Transmission. No Syncro 1st Gear. (B) was Borg Warner T-85N 3 speed Overdrive.
(1) It's a V8, not an I-6, so it does not have a Light Duty Transmission. (2) It's a 1963, not a 1961 or 1962, so it has 1st gear syncro. (3) B = Borg Warner T-86 3 Speed O/D ~ T-85N O/D wasn't available until 1965.
C = 292 2V
R = San Jose CA Assembly Plant.
362037 = 1963, assembled December 1962.
114" Wheelbase.
J = Rangoon Red.
F100 2WD, 5,000 lbs. GVWR
66B: 66 = Unit Body Pickup / B = Custom Cab.
A = Ford type 3.03 3 Speed Manual (w/a 292: Medium Duty) all Syncromesh Transmission / Introduced in 1963: F100/250's & Ford/Merc V8 Passenger Cars.
12 = Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
146 net HP @ 3,800 RPM (160 gross HP @ 4,000 RPM).
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
#148
F10 = F100 2WD
C = 292 2V
393787 = 1963, assembled March 1963.
114" Wheelbase.
Y = Glacier Blue.
F = Borg Warner T-98 4 Speed Manual Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
135 net HP @ 3,800 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
C = 292 2V
114" Wheelbase.
Y = Glacier Blue.
#150
