Best way to rustproof frame
I have a 1990 F-350 Frame shrotened for 6 foot bed. There is no rust on the frame or very little, I have everything off the frame that will come off, and I am abouyt to sandblast. I was trying to get it hot dipped-galvanized but no one will do it. What will work best
How about POR-15? ive seen it used on tv and the equipment renter down the street, they say it works wonders. The only down side i see is its not the cheapest thing to buy, its like 2500 for a 55-gal drum (I dont know the price on a quart, gallon. etc cause i havent looked it up for a few months and the price on 55-gal stuck in my head). I plan on using it on my '89 F-350.
I've been checking into POR-15 it sounds pretty good but it does not have UV protection. The galvanizing Idea is good but I've talked to every galvanizing place wit ha big enough tank in about 10 different states and none will do vehicle frames unless there fabricated frames. I was thinking of useing something like ryst bullet or miracle and putting on like threee coats and then having the frame sprayed with bedliner? oh yeah POR-15 is $117. a gallon from them
You might want to take a look at the frame I just finished for my sons Unibody here: https://www.ford-trucks.com/forums/5...1%21%21-a.htmlI had it sandblasted then I primed it with an epoxy primer. Used a product called "Body-Shutz" by 3-M, it's a undercoating that can be painted. I used it on the inside of the frame, then painted the whole frame with "hardend" acrilic paint. I have used this system on many hot-rods I've built over the years, and have never had a problem with rust or paint flaking off.
FABMANDELUX.
FABMANDELUX.
Chevmn56
05-06-2014 06:32 PM
