64 f100 292 motor mounts
1961/64 F100/250 292 292 2wd Motor Mounts
The front motor mount is center mounted, TWO pieces: upper and lower, both are round.
1) C1TT6A061C .. Lower Mount
1) C3TZ6068D .. Upper Mount
There are four rear mounts, upper and lower, right and left. All four are round.
2) C1TT6A061C .. Lower Mount
2) C3TZ6068D .. Upper Mount
Yes..all the upper mounts are the same part number as are the lower mounts.
Obsolete Ford parts dealer greensalescompany.com has (10) C3TZ6068D, but none of C1TT6A061C.
Green Sales: 800-543-4959
Info source: 1957/63 & 1964/72 Ford Truck Parts Catalogs
The actual Ford part numbers I typed above in BLUE.
If you have 2WD, the mounts are as I described above.
Two round front mounts, upper and lower. You only see one, but there's another below.
Two round rear mounts per side, upper and lower.
