F250 auto.: back-up lights stay on
On my 2002 F250 4x4, 5.4L, automatic, the back-up lights won't go out. I first noticed it a week or so ago, but thought it was caused by the trailer I had connected. I also sometimes hear a clunk after shifting from park to drive and pulling off. Yesterday in a parking lot, it sounded like a chain dragging for a second or two. I thought it was someone doing something in the parking lot until someone told me my back-up lights were on. Maybe the sound was my truck.
I've had the truck two years and about 40,000 miles. I haven't changed the transmission fluid. I bought the truck at a dealer and assumed it was changed there but could be wrong. I don't see how that could be connected to the back-up lights staying on but maybe it has something to do with the clunks and the lights are a coincidental diversion. The truck has the towing package and a trailer brake unit, though I've never used it.
Otherwise, the truck runs fine. Thanks for any tips.
Doug
Doug
Thanks for the information. Does the transmission need to be in park or neutral or are there any other steps to properly install the switch other than removing the old one and installing the new one? On my '67 Mustang I have to line it up so a wire can go all the way through a certain hole before installing.
Since the sensor was cheaper than a scan, and a 30-year mechanic I talked with said, "What else could it be?" I bought and installed a new sensor. The back-up lights are still on. Also, I had another problem a couple of times now: The shifter won't shift out of park, as if I don't have my foot on the brake. I turn the key off and shift into neutral to start the truck, then the shifter works fine. Are these two problems connected?
Doug
Doug
I replaced the fuse. The shifter has worked fine since but it hung up only twice in a week before and worked fine many other times, so it's hard to say if the fuse was a problem.
The back-up lights still stay on all the time. As another post in another thread instructed, I turned on the headlights then disconnected the battery overnight to reset computers, but the back-up lights still stay on, in all headlight switch positions and all ignition switch positions. For the time being I've disconnected the back-up lights. Any tips for a fix are welcome.
Doug
Doug
