2000 f-150 How many quarts of oil - Ford Truck Enthusiasts Forums
Old 07-30-2006, 06:19 PM
Impacttec1 Impacttec1 is offline
Impacttec1 is starting off with a positive reputation.
Hello,
I just got my 2000 f-150 4.6 litre from a friend. No manual was in the car. How many quarts of oil should I put in.
Thanks
Mike
Old 07-30-2006, 06:23 PM
Kijutsu's Avatar
Kijutsu Kijutsu is offline
Kijutsu is starting off with a positive reputation.
My book from a 1998 quotes six quarts of oil. My suggestion, put four in, check it. Add a fifth quart. Check it, start it to get it circulating. And then check it again. Probably will need the sixth.
Old 07-30-2006, 07:01 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is online now
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
My manuel from my 97 says 6 quarts. Like Kijutsu said, just put about four or so and keep checking it from there till you find the sweet spot.
Old 07-30-2006, 11:16 PM
markmartin6fan markmartin6fan is offline
markmartin6fan is starting off with a positive reputation.
my 2000 with a 4.6 takes 6 qt
Old 07-31-2006, 12:44 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Just dump in 6qts, and she will be right at the top mark on the dip stick.
Old 07-31-2006, 11:54 AM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
Actually, for most of these engines, 6 quarts will put the level about midway in the "O.K." range. That's why the dealers will often charge you for 7. If you feel the need to be full-up, you will probably need 6-1/2 qts.; but as the manual states, 6 quarts is adequate.
If your dipstick shows full with 6 quarts, you may have some sludge build up in the pan, or the oil did not drain completely. To a point, this is no cause for alarm.
Old 07-31-2006, 01:25 PM
bigdaddyII's Avatar
Mine takes 6.5 quarts but I just quoted what the manuel says, cause 6 will put it in the safe range but 6.5 tops it off to the full line.
Engine oil capacity for 4.9 liter 300 i6 brosko80 Ford Inline Six, 200, 250, 4.9L / 300 25 02-22-2006 08:11 AM
How many quarts does tranny hold? mshumack 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 11-04-2002 03:21 PM
How much oil do you guys use in a 390? 75explorerxlt FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 10-01-2002 10:10 PM
how many quarts of oil in an 89' 302? shotgunner426 1987 - 1996 F150 & Larger F-Series Trucks 3 02-02-2002 12:46 AM
how much oil goes in a 300 straight 6? familyman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 11-13-2000 08:53 AM
Tags
2000, 2004, 46, expedition, f150, f150how, fird, ford, heritage, liter, motor, oil, qts, quarts, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
