351w crown vic police interceptor engine - Ford Truck Enthusiasts Forums
Old 07-30-2006, 12:57 AM
cw95bronc cw95bronc is offline
cw95bronc is starting off with a positive reputation.
I can get my hands on one with 50000 miles, fuel injected it was running strong until the car was totaled but nothing is wrong withe the engine, I know it will fit blaa blaa blaa. My question will this engine work well in a 95 with the 96 upgrades bronc as is, don't have time or the ability to rebuild? Mostly looking as a drop in. I know the 302ho out of mustang or what ever else is not a good set up for for the bronc wrong power range. Just wondering about this. I did search the forums found plenty on the 351 swap but none involved this type of engine.
Thanks for any info.
Old 07-30-2006, 01:02 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
You are still dealing with an engine with the cam and valvetrain for a car rather than a truck. While the Crown Vic is a bigger car than an Mustang, the torque developement may still be a bit on the high side for the Bronco.
What exactly do you mean by "96 upgrades"? The entire engine family underwent the change from the original EEC-IV system to OBD-II between the 95 and 96 model years in the trucks. Not sure about the cars. There are significant differences in computer and sensor arrangements between the two years. It really depends upon how much of the setup you want to use. If you are talking just the longblock, then the only concern is that suggested in the first paragraph.
Old 07-30-2006, 11:39 AM
Thanks greystreak, I enjoy reading your posts, good info
Yea, that is what I was thinking about the torque and hp band. I thaught maybe it would be close enough to the truck version due to weight of pi vics. I don't know much about vics, also might be a cam to gear ratio problem. I know cams are sensitive to the gear ratio running. Mostly looking at the long block.
My bronc was manf. 06 95 so most parts I've been finding is the same as 96. For some reason there is a difference from late 94 to 04 95.
What about this train of thaught, if the rear axle is a 3.55 ratio on the bronc and the vic is 3.23 roughly again if, with the numerically higher ratio, wouldn't the 355 gears counter act the higher power band of the vic. Or should I say the gears allow the engine get to its band quicker? Or am I not in the ballpark with this thaught.
Again Thanks for the info
Old 07-30-2006, 08:01 PM
It might... I say might because I have no idea what the gearing through the transmission is on the C/V's. The only time you are dealing with JUST the rear end gear ratio is at cruising speeds or after the torque has been developed and the vehicle is moving. Perhaps with taller rear end gears you could achieve the necessary rpm's to put the C/V engine into its band. You would need to compare results from the tire size/gear ratio formula (I've posted it several times in various threads or you can check out gear vendor websites that have this calculator built into them) to see how similar the two setups are and just how much it would change based on the difference between the Bronco tire size and the Crown Vic's along with the gear ratio difference.
Old 08-01-2006, 06:24 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
They may have a better cam cause I think ford dropped marine cams into those engines just like they did the 302HOs in the GTs
Old 08-02-2006, 04:07 PM
bossind's Avatar
bossind bossind is offline
bossind is starting off with a positive reputation.
Those police intercepter motors didn't have anything special in them, just dual exhaust, silcon hoses.
Old 08-02-2006, 09:09 PM
GypsyR GypsyR is offline
GypsyR is starting off with a positive reputation.
Bossind is quite correct. Even the Police 5.0 Mustangs used as "Interceptors" had absolutely nothing special done to the engines themselves by Ford. Likewise though many a 351W was used in a Police car none of them were "Interceptors" nor special in any way. And since Police cars starting in 1991 used 4.6 modular engines, we KNOW the engine you're looking at isn't a roller cam. Roller cams didn't show up until 1994 in trucks with block casting numbers starting with "F4TE..". So you may have a roller cam engine now and will most likely be trading down to a "flat tappet" engine.
BTW, some of the newer 4.6 Police engines (and cars) ARE designated as "Interceptors" by Ford and do in fact differ a bit internally from mainstream 4.6 engines.
Old 08-02-2006, 09:33 PM
cool
I can accept that, thanks for more good info. The main question was cam in relation to gear ratio. I did not realize that they would have been non roller. So I'll pass on that set up. Thanks everyone.
Old 08-02-2006, 10:25 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
A 351 engine from a PI is carbed.
You are losing power over a 302 if that is truly what you have in your hands.
no reverse gjnicholas 1978 - 1996 Big Bronco 35 03-25-2011 12:01 PM
4R100 life expectancy? 68 351 bronc 1999 to 2016 Super Duty 13 11-10-2010 05:31 PM
rear auto locker or not? stock FSB towing and DD. cw95bronc 1978 - 1996 Big Bronco 13 04-29-2010 06:11 PM
30-40 mph hesitation masseysbronco 1978 - 1996 Big Bronco 6 12-14-2004 10:37 PM
Whats The Plug Gap For 79 351/400 79 bronc 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 12-07-2004 12:12 AM
Tags
1991, 351, 351w, difference, engine, ford, intercepter, interceptor, motor, mustang, nonroller, police, roller, sho, specs, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
