Upper Kingpin Won't Take Grease--What to do?
on
1 Post
My upper kingpin won't take grease. Well, it might have taken a tiny bit, but not much, not even one good squirt. The lever on the grease gun just was rock solid and nearly impossible to move. I even changed the grease nipple and it still wouldn't. The other upper took about 10 squirts and it came out like it is supposed to.
Does this mean there is a problem with the kingpin?
Should I jack it up and try to grease it without the vehicle weight on it?
Should I try to have a power grease gun do it?
Thanks
Thanks
on
1 Post
This is a 1997 Class A motorhome chassis. I jacked up the wheel on that corner and was able to get some grease in, maybe 4 pumps. It was a bear of a squeeze on the lever, but it seemes to have worked. Still nothing seemed to come out the opposite gap. I'm going on a 500 mile soon and will try again after the trip. Maybe it will work loose. And yes I did change the zerk fitting, using an angled fitting the last time, which worked much better for removing the grease gun.
Y2KW57
30
10-26-2020 11:33 PM
Greywolf
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
26
05-14-2018 09:35 PM
AMSContr
10-20-2008 12:12 AM
