dizzy switch
Old 07-27-2006, 04:38 PM
hash's Avatar
hash
hash is offline
dizzy switch
I have a new unilite with vac adv, can i be changed to mech adv?
Old 07-27-2006, 06:27 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
The dist. already has a mechanical advance in it, along with the vacuum advance. Unless this is an race vehicle that never runs on the highway or you don't care about gas mileage, why would you not use the vacuum advance? It only works at little loads and little throttle settings anyway and helps improve gas mileage..
Old 07-28-2006, 10:38 AM
hash's Avatar
hash
hash is offline
This truck is a weekender, so gas mileage isn't a great concern. I've been having trouble at idle, the port on the side of the holley carb is pulling vac and advancing the timing to max.
I've opened up the rear throttle plates to lower the mains, that helped. I also adjusted the vac adv screw on the dist, that helped. With that done, it doesn't run that great at idle. I have used different intial timing from 10-15 btdc but that has had little effect.
Since the dist has both vac and mech adv, can I just block the vac adv port?
Old 07-28-2006, 10:46 AM
fordraceboy's Avatar
fordraceboy
fordraceboy is offline
have you adjusted the vacuum advance can? there's a allen head screw that's accessed through the vacuum port on the advance cannister where the hose goes on it. i think it's a 3/16th allen wrench but i'm not sure. turn the screw clockwise until it stops and that is zero advance. every complete turn counterclockwise is 7 degrees advance i think. the mallory website had all this info when i was having some trouble with mine- it turned out the screw was stripped and wasn't limiting the advance...
Old 07-28-2006, 10:47 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Hash, what cam did you use?
When you get into the bigger cames (like the Crane 941) you have to do certain things to get the vacuum port to not pull vacuum at idle, which you seem to already know if you're playing with the secondary plates. HOWEVER - that is a band-aid and will still ruin your idle because the secondaries don't have an idle circuit and to make up for it, you need to richen the front idle circuit way up, which doesn't help the mix AT ALL...
Bear, if he has a big cam, think it's time to drill the primary throttle plates so they can be shut to where the vacuum advance port doesn't pull vacuum anymore?
Old 07-28-2006, 12:35 PM
Bear 45/70's Avatar
Bear 45/70
If you are pulling vacuum at idle on the ported vacuum port the the carb is setup wrong. No two ways about it as the vacuum port's sourse is covered by the throttle plates at idle if the carb is setup properly.
Old 07-28-2006, 12:55 PM
hash's Avatar
hash
hash is offline
crane 941
holley 750 vac sec dual feed
Old 07-28-2006, 05:11 PM
Bear 45/70's Avatar
Bear 45/70
If all the other setup is right, yes on the holes. But the Crane 941 shouldn't cause that kind of problem.
Rusty_S
09-03-2012 08:12 PM
rustyranger390
10-05-2011 08:47 PM
marvinlong
1997-2006 Expedition & Navigator
08-09-2011 06:12 PM
markal
08-23-2007 07:15 AM
Schmitty
Computer Chips & Tuners
05-02-2004 01:30 AM
Quick Reply: dizzy switch
