Dangerous side to side front wobble - Ford Truck Enthusiasts Forums
Old 07-27-2006, 06:41 AM
Peter Richards Peter Richards is offline
Peter Richards is starting off with a positive reputation.
I have a 1997 F150 Lariat Supercab that has a side to side wobble in the front end. It only happens when driving between 50 & 60 kilometers per hour when you hit a large bump in the road, and only stops by slowing down to almost a full stop. I was told it was shockies which I replaced, and that seemed to stop it for a month or so, but now it is back. Here in Australia nobody has any experience with these vehicles, any ideas?
Old 07-27-2006, 07:10 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Check wheel bearings, upper and lower ball joints and the complete steering linkage.
Steve
Old 07-27-2006, 08:01 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Check the track bar.
Here is a test procedure.
Start the engine.
Watch the front center of the hood.
Slowly move the steering wheel 2 or 3 inches in both directions.
If the body moves the bushings are worn.
This is often referred to as the death wobble.
It happened to me once and I wanted to leap out of the truck.
Old 07-27-2006, 11:04 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
Have the tie rod ends been replaced yet? If not, now is a good time to replace them. I have had this same scenerio when tie rod ends were fixing to let go. Also, if the ball joints have not been replaced, while everything is already apart, do those also. The track bar bushings are the easiest and cheapest but their most important role is to keep the truck level while going around a curve.
Old 07-27-2006, 05:49 PM
marshall99f150 marshall99f150 is offline
marshall99f150 is starting off with a positive reputation.
you know, i had this same problem with my superduty.. couldn't figure it out.. well i put new tires on and that totally fixed the problem.. do you have all terrain tires or mud terrain tires? if so, that may be your problem.
Old 07-27-2006, 06:25 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
lower ball joints will do that when you hit a bump. on annother note, if it happens during deceleration only, then you look at the idler arm anchored under the radiator on main frame.
Old 07-27-2006, 07:45 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
it is two wheel drive or 4? is it lifted or stock?
Old 09-19-2006, 07:21 AM
Thanks for your help boys, it ended up being a flogged out pitman arm.
Death Wobble shawbran 1999 to 2016 Super Duty 1 09-08-2015 01:11 PM
death wobble help! bab350 1987 - 1996 F150 & Larger F-Series Trucks 5 07-25-2014 05:12 AM
Steering Wheel Wobble atomrat 1999 to 2016 Super Duty 10 07-13-2014 07:56 PM
steering wheel wobble schonauer 1999 - 2003 7.3L Power Stroke Diesel 2 05-08-2014 03:40 PM
Lift kit on a 79 F150 with Reverse front leaf shrekau 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-11-2014 03:34 AM
Tags
2003, 97, body, curve, driving, f150, f350, ford, moves, side, tires, truck, wobble, wobbles, wobbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
