Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 07-26-2006, 08:10 PM
dng dng is offline
dng is starting off with a positive reputation.
Cool ford escape >> back door & glass wont open
2001 ford escape. cannot open back door and glass. there is no kep option, only auto and they are not working. checked fuses, all other doors working fine,
does anyone have any suggestions?? i was hoping to move this weekend and
need to get in the back door. does anyone know if there is a safety latch? or possible child lock? any suggestions would be great and very welcomed.
thanks again,
dale
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-27-2006, 06:09 AM
IB_Tim's Avatar
Administrator
IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #3 (permalink)
Old 07-27-2006, 06:59 PM
BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.
no saftey latch to my knowledge. heres a couple of guesses. one is that the actuator is not unlocking the liftgate. when this happend the glass and liftgate wont release. guess two is the plastic clips couls have broken on the latch itself. dont try to remove the panel without getting either glass or the door opened or you can damage the trim panel. try pressing the unlock button and see if you hear a noise coming from the door panel. you should hear something.
  #4 (permalink)
Old 07-28-2006, 09:02 AM
bananaboat is starting off with a positive reputation.
Sounds like the actuator. Has this Escape had any service performed on the back hatch in the past? If so, you might have a rod problem. The rod issue is related to the hatch opening during a rear impact, don't know if it could have the opposite issue.
Recall 04V602000: Liftgate Latch Release Rod Replacement
Certain 2004-2005 sport utility vehicles and certain 2001-2003 sport utiity vehicles having rear liftgate components serviced with 2004 equivalent components fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 206, "Door Locks and Door Retention Components." The rear liftgate latching system does not meet the inertia load requirement in one direction.
  #5 (permalink)
Old 07-28-2006, 09:26 AM
dng dng is offline
there is no sound when i click the unlock button. usually i can hear this when i click the button on the keyless entry twice. there is no keyhole so i guess i may have to take it into the shop? i've nver had any issues with this nor has there been any rear hits.
d
  #6 (permalink)
Old 03-02-2008, 10:29 AM
86fxstc is starting off with a positive reputation.
Did you ever figure out why your back door and galss wouldn't unlock? I have a '01 Escape and have experienced the same problem. It works sometimes and sometimes it doesn't. I want it to work all the time.
  #7 (permalink)
Old 05-17-2008, 09:41 AM
dehamma's Avatar
dehamma is starting off with a positive reputation.
I have an '02 and I am having the same problem. It is very inconvenient. I noticed that there is an access "window" that accesses inside to the actual latch. I played around with it and was not successful. Does anyone have some knowledge of tripping this latch? At least if the liftgate can be opened, I can have better access to issue.
__________________
1989 F150 XLT 4.9L 4X4
8.8 / Dana 44
M5OD / B-W 13-65
"Old trucks don't shake... they "wobble". That's what old trucks do."
-Paul Newman
"When the power of love becomes more important than the love of power, then there will be peace."
  #8 (permalink)
Old 05-20-2008, 11:06 AM
goingnorth is starting off with a positive reputation.
I have an 08 xls and have the same problem, sometime it works, always works fine at the dealer.
  #9 (permalink)
Old 05-26-2008, 09:13 AM
2fords2 is starting off with a positive reputation.
I had this happen twice on my '01. Ended up taking it in to the dealer and had the module assembly (whatever that is) replaced first, and just three weeks later had the handle/lock mechanism replaced. Not having a key hole on the outside or a way to open the rear hatch from inside the vehicle is one of Ford's dumb and dumber ideas.
  #10 (permalink)
Old 06-02-2008, 02:05 PM
dehamma's Avatar
I had the same problem with my '02 Escape. Get in the back and pull the interior panel off from the top. It is held on by insert clips. After that, your problem (or mine was) the actuator that lacks the glass and door. Just move the actuator rod up to allow thw latch to work. My actuator is bad so I left it up to use the hatch and glass, but I can't lock it until I replace the actuator.
Hope this helps.
__________________
8.8 / Dana 44
M5OD / B-W 13-65
-Paul Newman
  #11 (permalink)
Old 06-15-2008, 10:44 PM
aliounis108 is starting off with a positive reputation.
Hey guys i listened to what you have to say and it worked only issue is before is my alarm used to work when i locked all the doors but now it will not work when someone goes and opens the back door.
  #12 (permalink)
Old 06-16-2008, 10:54 AM
tcesni is new and has a neutral reputation at this point.
Ironically, my 2002 Escape does have a key hole for the back hatch.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
