Wiring Diagram needed for a 2001 Ford Ranger 2x4 w/ 4.0L engine - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-26-2006, 01:56 PM
swogee swogee is offline
swogee is starting off with a positive reputation.
Question Wiring Diagram needed for a 2001 Ford Ranger 2x4 w/ 4.0L engine
I'm looking for a wiring diagram for a 2001 Ford Ranger 2x4 w/ 4.0L engine.
I am seem to be having a problem with fuse 2 blowing all the time. Fuse 2 supplies the blower motor relay, DRL's, transmission, back-up lamps, and the passenger airbag deactivation switch.
I'm not sure if this is a problem that occurs commonly on Rangers but if anyone has seen a problem like this and knows what the solution is please let me know.
I need a wiring diagram to diagnose the cause of the blowing fuse.
Thanks in advance.
-Steve
Old 07-26-2006, 02:11 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
When you put a new fuse in does it immediately blow? Or do you have to do something special to get it to blow? Bad ground?
Old 07-26-2006, 03:09 PM
The fuse blows quickly. The fuse seems to blow mostly when the A/C unit is operating, however there has been at least one time when the A/C was not on and the fuse did blow. (A friend also stuck a 20 amp fuse in place of the normal 10 amp fuse and turned things on before I was able to stop him and the 20 amp blew as well.)
The description in the owners manual of what the fuse supplies power to is not all that informative unfortunately.
I was hoping that there was some common issue that might be causing this blown fuse that I would be able to check on, but that is not highly likely it seems.
I'm not planning on working on the problem until this weekend, but a wiring diagram would be helpful in tracking the short down.
-Steve
Old 07-26-2006, 05:39 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Welcome!
If you hurry, you can download a PDF file of the diagram you need from HERE. The PDF file won't be there too long, so make sure you save a copy to your harddrive.
Good luck with the troubleshooting.
Old 07-26-2006, 05:45 PM
Hopefully someone will chime in with the wiring diagram for '01, mine only cover '93-'00. Autozone.com also has them sometimes, check there.
Old 07-26-2006, 07:43 PM
Wink
RangerPilot,
Thanks for the advice on Autozone. I checked there and unfortunately they only go up to the 1999 Ford Ranger and the diagram isn't complete.
Rockledge,
Thanks very much for the link. It will be very helpful during my search for the cause of the blown fuse. I really appreciate it.
-Steve
Old 07-26-2006, 07:52 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
super sponsor to the rescue :-), I'll send you a copy. what is your e-mail or fax number?
Ed
Old 07-26-2006, 08:43 PM
natebaker's Avatar
natebaker natebaker is offline
natebaker is starting off with a positive reputation.
Nice! You're a good man ^^
Old 02-09-2016, 10:16 PM
ritchi91917 ritchi91917 is offline
ritchi91917 is starting off with a positive reputation.
Question
hey man did you figuer it out i know this an old post but i got the same problem
Old 02-10-2016, 10:31 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE.
This is a 10 year old thread you've opened!!!!
From the info you've posted I'm not certain what you need, but you might try here Search Wiring Diagrams & let us know how it goes, but open a new thread at the upper left in the forum index page here http://www.ford-trucks.com/forums/forum35/, so you get answers just for your needs.
2000 ranger wiring problems madizon1420 Ranger & B-Series 1 04-15-2016 07:36 PM
Alternator Wiring Issues, Blown Fuse? Bubba Hines 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-19-2015 10:06 PM
Fuse panel diagram BcLivin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-12-2015 09:40 PM
Fuse block diagram needed 78 & 87 Super Cab Ranger & B-Series 1 04-09-2014 05:10 PM
Non-traditional electrical gremlins diagnostic procedures? dpilot83 1987 - 1996 F150 & Larger F-Series Trucks 0 10-19-2012 08:14 AM
Tags
1999, 2001, 2003, 30l, 40, 40l, diagram, diegram, engine, ford, fuse, pdf, ranger, wiring, woring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
