Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint & Bodywork
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
  #1 (permalink)
Old 07-26-2006, 10:55 AM
mudding4life's Avatar
mudding4life mudding4life is offline
Garage is empty, add now
mudding4life is starting off with a positive reputation.
Need A Good Rust Converter
Im looking for a good rust converter anyone know of one?? And also does a rust converter really work???????
  #2 (permalink)
Old 07-26-2006, 01:05 PM
sonofa75 sonofa75 is offline
1975 Ford F-100
sonofa75 is starting off with a positive reputation.
Thumbs up
I like Rust Restorer, (simuliar to por15) but cheaper. This paint is tough. Paint right over rust, very hard, great gloss finish. Not to big on the idea of corrosion covering materials, I sandblast or grind all rust out, then paint this over it.
Mainly used on frames, firewalls, but could easily be sprayed on panels.
35$ a quart
give this a try this is the @$it!!!
http://www.safestrustremover.com/
  #3 (permalink)
Old 07-26-2006, 04:16 PM
Terran's Avatar
Terran Terran is offline
Terran is starting off with a positive reputation.
I used POR 15, it really does work good, i usually scrape off all scale with a wire brush and put POR 15 and one of their top coats on. That's how i'm doing my frame/floor.
__________________
79 Ford F-100 'Ol Blue (My daily driver)
74 VW Bug
90 Nissan 240sx
01 Honda Ace 750
  #4 (permalink)
Old 07-26-2006, 06:19 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved to proper forum.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #5 (permalink)
Old 07-27-2006, 06:23 AM
Has anyone heard of a product called Ospho is it a good product????????
  #6 (permalink)
Old 07-27-2006, 08:52 AM
pbr man pbr man is offline
pbr man is gaining momentum as a positive member of FTE.
Check out Rust Bullet. Easy to use and needs very little surface prep.
http://rustbullet.com/Products/Automotive/Automotive.htm
__________________
Eric 1999 F350 4x4 Super Duty, Crew Cab Long Bed,7.3 Diesel, 6 speed, 4'' Diamond Eye exhaust, 4040 Aeroturbine, Dipricol Optix-boost and pyrometer, AIH delete, Hutch and harpoon, Tuff Country Add a Leaf
Democracy is two wolves and a lamb voting on what to have for dinner-liberty is a well armed lamb contesting the vote" Thomas Jefferson
  #7 (permalink)
Old 07-27-2006, 10:31 AM
Carlene's Avatar
Carlene Carlene is offline
FTE Administrator
1964 Ford Falcon
My Garage
Carlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputation
Hey mudding - welcome to FTE.
The guys have given you good options for a rust paint, but as for the converters, I prefer either Ospho or Metal Ready. Ospho has a longer curing time than Metal Ready, but both work very good. I've used both on our 1941 PU and on many other projects. Oshpo is much cheaper and easier to come by. You can find it at most any paint store and I get mine at Home Depot.
Mind you though, it is just a converter. You will still need to paint over it to help keep the rust from returning.
Do a search of this forum for Ospho and you should find much information.
__________________
Carlene
FTE Guidelines
Check out the Florida Chapter
  #8 (permalink)
Old 07-27-2006, 11:21 AM
Thanks for the info every little bit helps.Im trying to get the best stuff for my 79 f100 4x4 and do it rite the first time so i dont have to keep going back to the same spot to do it over again.Thanks
  #9 (permalink)
Old 08-02-2006, 07:19 PM
99f350sd 99f350sd is offline
99f350sd is gaining momentum as a positive member of FTE.99f350sd is gaining momentum as a positive member of FTE.
If you are not going to sand blast. Use picklex the rust bullet. Nothing else comes close. Stay away from those products that turn black. they are junk. If you are going to sand blast do the same picklex and rust bullet. Follow directions.
Dick
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..MDII Plow, 200 amp alt timbrens,Revo's
THREE 96 aero*awd 4.0 ext. GREEN,BLUE,WHITE
2010 SUZUKI SX4 AWD CVT NICE
USAF 76-80
CX500 TURBO ORIG OWNER
  #10 (permalink)
Old 08-03-2006, 10:37 PM
hot1958 hot1958 is offline
hot1958 is starting off with a positive reputation.
i like mar-hyde one step.it work's good and set's up like concrete.
__________________
build it strong,and drive it like you stold it.
  #11 (permalink)
Old 08-06-2006, 05:22 PM
justshootme84 justshootme84 is offline
justshootme84 is starting off with a positive reputation.
mud, I use OSPHO all of the time and have for years. IT's cheap, covers alot of surface, can be brushed or sprayed on, and can be painted ovre with minimal prep ( just remove white residue). I restored the frame on my 84 Bronco, and have several pics at superford.org I also have some pics of OSPHO vs "Restore" rust converter. That product is fair, leaves a clear, hard coating and a black color, can be painted over. JSM84
__________________
84 Bronco XLT, 460, C-6, Dana60, Sterling 10.25", 36" GYR RT-II's, Herculiner, S&W 10-pt cage kit, PRP racing seats, "Shaker"
88 Bronco Custom, 302 EFI, C-6
86 Bronco Custom, 300 I6, NP-435
78 Bronco Custom, 351M, NP435, 38" TSL's
79 F-150 4WD, 351M, C-6, 35" MT's
  #12 (permalink)
Old 08-07-2006, 02:18 PM
Where is the best place to pick up ospho i have heard it's a real good product??????
  #13 (permalink)
Old 08-07-2006, 11:24 PM
Most auto parts and some harware stores will have OSPHO. May have to search a few places to find it, and don't be fooled by imitations. Cost should be no more than $20/gallon, it's like $15/gal here at the local NAPA. Alot of it gets used here along the Gulf Coast.
I tried to post a link to my SFO gallery, but it failed. Go to www.superford.org (or www.supermotors.org), and look in my gallery for the 84 Bronco under axle pics and rustproofing frame.
Randy Zrubek, Justshootme84
Try this:
84 Bronco
__________________
  #14 (permalink)
Old 08-08-2006, 09:25 PM
rboeding rboeding is offline
rboeding is starting off with a positive reputation.
I found something at Advanced Auto called Right Stuff. It looks like green koolaid. I pulled my front suspension apart and while it was out I cleaned the grease and dirt with a power washer. I then sprayed this stuff on it and let it sit over night. The next morning the metal was smooth and almost a gloss black. There wasn't alot of rust there to start off with but a 30 year old i beam has a little. I wasn't worried about them rusting through but I thought that they would look better not rust red. I was very pleased. The felt like they were new. No pits and they looked real good. The best part is the stuff cost 4.98 per quart. Now, everthing that I see that has rust starting or developed I spray with this stuff. I will go back and repair the serious stuff latter but I feel like at least the rust has stopped where I spray it for now.
  #15 (permalink)
Old 07-17-2008, 11:11 AM
raubuch raubuch is offline
raubuch is starting off with a positive reputation.
The best rust converter that I have found is Corroseal.
Tags
best, bullet, convert, converter, converters, depot, home, napa, ospho, osphor, paint, primer, restore, rust, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
