2wd to 4wd conversion - Ford Truck Enthusiasts Forums
Old 07-25-2006, 06:09 PM
healinhand healinhand is offline
healinhand is starting off with a positive reputation.
I have a 96 f-250 powerstroke 2wd, Would be interested in converting to 4wd. Any suggestions? Thanks Gary
Old 07-25-2006, 07:18 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
buy a new truck, second plan buy a wrecked truck and convert. You will either need to replace or completely disassemble your trans to change the outpur shaft and tail housing of your trans, then you need t-case, driveshaft, axle (dana 60 best) steering linkage, springs and hangers, track bar and bracket, shifter (hole in floor)and maybe a few others i have forgotten.
Really to be honest with you buying a 4wd truck will be much better. i know would have a hard time getting rid of my truck too but even though i am a mechanic with a shop full of tools and equipment and knowledge i would find a different truck.
Old 07-25-2006, 08:41 PM
Briansshop's Avatar
Briansshop Briansshop is offline
Briansshop has a good reputation on FTE.Briansshop has a good reputation on FTE.
This is the same truck, did the conv. myself. tj hit on what it takes to it.Gary,it wasn't a big deal to,I'd do it again.
Brian
Old 07-25-2006, 08:46 PM
Briansshop's Avatar
Sorry for the big size,hopefully one of the Mods will cut 'em down some.Still learning the picture thing.
Brian
Old 07-25-2006, 08:50 PM
Thanks
I really like my truck, I bought it new in 96, its got 297,000 miles on it. I just dont think I could give it up, but I need the 4X4. I have property in WA state and we get a lot of snow. Any more help would really be helpful. Thats a nice truck, by the way. Thanks Gary
Old 07-25-2006, 11:19 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD DAVID'S97F250HD is offline
DAVID'S97F250HD is starting off with a positive reputation.
I like the low rider look
Old 07-27-2006, 10:23 PM
Kenworth Kenworth is offline
Kenworth is gaining momentum as a positive member of FTE.
I got bad news for you a dually 4x4 is almost useless in the snow it won't do much better than the stock 2wd as the truck is now.
You will never gain anything converting the truck the cost isn't worth it. For winter use find yourself a 4x4 something like a old half ton and leave the dually for summer use. You put some weight in the dually you can get through the snow and run a good aggressive tire.
Old 07-27-2006, 10:54 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.
I have a 95 dually and I am trying to decide on converting it to 4wd or getting another 95-97 F-350 4X4 and converting it to a dually. I pull a 39 foot 5th wheel toyhauler and I want to get it on the sand. I like the replies, keep them coming.
Old 07-28-2006, 06:34 AM
tjbeggs's Avatar
healinhand's truck isn't a dually. its an f-250.
Old 07-28-2006, 08:24 AM
Quote:
Are you kidding me??? My F250 4x4 was converted into a dually, I never owned the truck with RSW but with my long wheel base that hurt me even more. I can not count the times that the 4x4 got me out of the snow, 2ndly, it is all in the tires just like a regular 4x4, most of the time I've seen a pretty lame all season on a duallys. 500lbs of weight in the box makes a world of difference. And if you really are the type of person that has to pound 5 feet of snow, have a set of winter rims and tires like Briansshop has. The $x4 has gotten me out of alot of trouble many times. Even with ice driving on the highway
My 4x4 dually managed to yank out a chevy truck out of the mud, I was on solid ground of corse, he had 33 inch tires sucked down in the mud with a broken axle. Using a block and tackle, another truck as my anchor I pulled that truck out up an steep incline. 800lbs of sandbags in the box for aid and the only traction I had issues with was my front end was bighting hard and hopping in low range. Got the chevy truck out, next day I was pulling the tranny out though.
Old 07-28-2006, 08:42 AM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
i'm not sure that makes any sense!
you dont have to have a 4x4 ZF to do this swap. find a divorced NP205 (outta be easy to find and run ya $100 max depending on your market area) and then find a D60. the 205 will hook to the back of your 2x4 tranny via a very short driveshaft. this will also help with driveline angles as you can set the t-case exactly where you want it.
the D60 will swap right in, however it'll be the most $$$ of the project. go ahead and figure $1000 is about average. 1200 is a lil much (unless it's a 78/79, which you dont want), and 800 is a good deal but beware and be sure to check it out make sure nothing is seriously wrong with it
i have 3 D60's sitting in my garage but gettin one to you but cost more than the axle if you found it in your area!
-cutts-
Old 07-28-2006, 10:03 AM
Quote:
Brian
wHAT KINDA RIMS ARE THOSE?
Old 07-28-2006, 04:27 PM
Briansshop's Avatar
David, those are Alcoas, I don't think they make 'em anymore.
Dually 4x4 no good in the snow? How could having a front axle w/ 4-4500lbs. riding on it not help out in the snow?
Brian
Old 07-28-2006, 05:12 PM
I'll live with my stainless covers I suppose
Old 07-28-2006, 11:34 PM
A dually in the snow floats on top the back wheels just spin on top. The snow on in the Pacific Northwest is wet it turns to ice soon as you spin your wheels on it. We have problems with people that are from east of the Rockies coming here in the winter time and figure we can drive in snow no problem. The biggest problem is the snow where they are from is drier its sticky so your tires bite into it. Here its wet and heavy you make a snow ball and throw it at somebody its like throwing a rock at somebody its hard.
In my area the highways dept can't even scrape the compact snow off the road with a 14G Cat Grader with a regular moldboard. The only thing that makes a dually bite through the snow is V bar snow chains and weight in the box.
Doing the conversion isn't too bad if your mechanically inclined.
2wd fascia ? 93-331-29PSI 6.7L Power Stroke Diesel 7 12-25-2014 05:31 PM
2wd vs. 4wd headers letsgomuddin85 Exhaust Systems 2 12-01-2008 09:53 PM
2wd vs 4wd transmission andrew240z 1999 to 2016 Super Duty 5 12-02-2007 06:43 PM
Steering stabilizer on a 2WD?? (1974) GeneStoner Brakes, Steering, Suspension, Tires, & Wheels 1 05-15-2003 02:22 PM
Converting 2wd C-6auto to a 4wd slushbox rebocardo Clutch, Transmission, Differential, Axle & Transfer Case 3 07-29-2002 08:01 AM
Tags
2wd, 4wd, 4x4, 86, 97, 99, conversion, convert, converting, dually, f250, f350, ford, good, kit, pickup, snow, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
