How do I
From my Ford Manual:
Disconnect the heater water hoses (18472) from the heater core (18476), and plug the heater water hoses.
For easier access, remove the glove compartment.
From inside the passenger compartment, remove the seven screws which attach the heater core cover to the heater air plenum chamber. It will be necessary to move a "RABS" module out of the way on F-Series prior to removing the cover.
Disconnect the vacuum source. Leave the vacuum hose harness attached to the cover. Remove the cover.
Remove the heater core from the heater air plenum chamber.
Old Brown F250
11-02-2010 07:15 PM
