Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #106 (permalink)
Old 05-14-2007, 07:20 PM
countrycar's Avatar
countrycar countrycar is offline
countrycar is gaining momentum as a positive member of FTE.
Nice And Cold!!!
Hey guys, I got the DS/AC kit last week end and did the install in about 30-min. I checked the the AC prior to the install and in registerd at 50 degrees. After the AC Mod I drove the truck for about 15-min and it got down to 42. Not bad. I have the remote start on my truck so the next day I did just that. I remote started the truck and after about 8-10 min's went by, I got in the truck to leave and I noticed that the thermometer was still in the vent where I had left it the day before and it was reading 30 degrees. It was about 85 out side so it wasn't too hot either. But that's a heck of alot better than it was. It could also be to the fact that I had a switch installed in my Truck that makes the AC cycle (ON) quicker too. I had an AC tech install this for me and it works great too. That could be why my truck got so cold .Take Care , Country.
__________________
  #107 (permalink)
Old 05-14-2007, 11:01 PM
husker husker is offline
husker is gaining momentum as a positive member of FTE. husker is gaining momentum as a positive member of FTE.
On the issue of a manual valve with a cable. That is how the temp was regulated on older cars and trucks that had a lever on the heater to control temperature. I have a 54 F250 with the old manual valve that operates off of a cable. That system would work. You would just have to use an after market choke cable or hand throttle and mount it somewhere inside the cab and run it to the manual valve if you wanted to be able to contol the water flow to the heater core. The valve on the old 54 just moves back and forth over about a 90 degree arc between off and on.
__________________
Del
2001 F250 SD PSD 4x4
78 Bronco
54 F250
48 F5
64 Thunderbird
  #108 (permalink)
Old 05-16-2007, 10:20 AM
Chorizo520 Chorizo520 is offline
Chorizo520 is starting off with a positive reputation.
Can anyone say for sure wich vac hose, white or red works better. I will need defrost
and like heat through the upper vents.
thanks
__________________
2000 250 4x4 CC. Hypertech, 4" Banks Exhaust, Shift kit, 315/75 Toyo's, 3.73's. Pulls 22' Toy Hauler, Bed Slide,Snug Top
  #109 (permalink)
Old 05-16-2007, 10:42 AM
countrycar's Avatar
Couldn't tell yah. I just did the straight up install according to the directions. It installs using then white Vac Hose..And it works only in the Max AC setting. The system works normaly after that. I like it this way myself..Take Care.Country
__________________
  #110 (permalink)
Old 05-16-2007, 07:49 PM
fixnair fixnair is offline
fixnair is gaining momentum as a positive member of FTE.
I agree with countrycar. The white hose is the best one to use. You will still have all the other selections working normally with only the Max AC having the water shut off.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
  #111 (permalink)
Old 05-16-2007, 11:33 PM
jtharvey's Avatar
jtharvey jtharvey is offline
Lost Soul
jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all
I would use the white hose. You've got the Max setting for some cold AC, but you know for sure that the rest of the system will function as normal.
__________________
Jeremy
See My Webshots for pics.
  #112 (permalink)
Old 05-16-2007, 11:52 PM
UcaN UcaN is offline
UcaN is starting off with a positive reputation.
a/c
Quick question.......a little off topic but not that far off
Is there any harm done when one leaves the A/C switch in the on position after shutting down the truck?
For example: say you are driving to work with your A/C set to max, then you get to work and shut down for the rest of the day but leave the settings as they were when driving (max A/C, high fan). At the end of the day you get into your truck and fire it up while the A/C settings are at max/high fan.
Does this practice harm anything??? Compressor clutch??? Fan blower? Many years back i remember Dad always made sure to set everything off before shutting down his cars. During the hot summer months here i usually leave everything on max and dont bother setting it off before i shut down my truck, i figured the less i turn those knobs the less wear on them.
what are your thoughts???
__________________
2000 crew cab, 4x4, short bed. Only mods so far - 6637, ccv, zoodad, intank mods with pre fuel filter, hpx crossover line.
  #113 (permalink)
Old 05-17-2007, 12:15 AM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
i am curious what others will say. my wife and i have argued about this for years. she turns them off, i leave them on. its always hot here anyway.
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #114 (permalink)
Old 05-17-2007, 12:33 AM
countrycar's Avatar
I'm not an AC tech so I won't even attempt to try to answer this one for yah. I also leave the controls in the on position in antisipation of what the weather is going to be like. Especially if the truck is going to sit for awhile or over night. I have the remote start so it makes it convenient. Creature comforts are great.LOL Take Care..Country
__________________
  #115 (permalink)
Old 05-18-2007, 01:25 AM
crosbo's Avatar
crosbo crosbo is offline
crosbo is starting off with a positive reputation.
Quote:
I would use the white hose. You've got the Max setting for some cold AC, but you know for sure that the rest of the system will function as normal. --jtharvey
JT, I think you missed the original point...a way to allow the AC to provide cooler air, while also allowing the vent mode to actually provide air at the outside ambient temperature...instead of the pre-warmed version that stock mode provides.
I be making this change this weekend. This time of year in the Hill Country north of San Antone, it's cool enough outside during early to late evenings to run with the windows down (love to hear that whistling exhaust), but the 3 females in the house complain of blowing hair...and the vent mode supplies air that is too warm, so on goes the AC...but with diesel prices the way they are, I'd rather run the vent. So, it's the red-line mod for me. I'd rather not have to wait for 100 degree outside temps to hit before vent mode finally feels cool.
But, that's why Baskin-Robbins has 33 flavors...and I suppose that's also why those butt-ugly new Chevrolets are hitting the streets...to each their own.
__________________
__________________
Tom
'00 CC F250 4x4 Auto 4" Magnaflow, S&B Cold Air Intake, AIH, Edge A2/Juice, HPX, Pre-pump, In-Tank, CCK, 203 Thermostat, Air Horns, XM Satellite Radio, 2" lift, 315's, Trucool 4739, '06 Grill and emblem upgrades, RealTree skins and a hot babe in the passenger seat!
  #116 (permalink)
Old 05-18-2007, 09:19 AM
I think I might try the red and if its not what I want change the new red t with an inline and give the white a try. Seems easy enough.
__________________
  #117 (permalink)
Old 05-18-2007, 11:02 AM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE.
As shown in the pic on my post #97 on this thread, all I did was insert a shut off valve in the top hose. Now, it seems that the A/C compressor never cycles off no matter how cold it gets. Is it possible that the A/C compressor always ran all the time before, and the knob to control temp (cw for hot & ccw for cold) was actually controlling the supply of hot water to make the exit air hotter or colder???
__________________
2005 Freightliner ext cab M2 Mountain Master RV Puller, CAT C7 300 HP, 6 speed Allison TRV3000, air locker 4.33 diff, Michelin 255/80R22.5 LRG tires, pulling a 2008 40' triple axle HitchHiker.
  #118 (permalink)
Old 05-18-2007, 11:14 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Quote:
You are correct Ernest...the dumbest air-conditioning system ever invented . That is why when you do any of these mods that completely shut-off the flow of hot water to the heater core, you lose control of the temperature of the air conditioner and it runs cold...real cold. The only control of temp that is left is the fan...Makes me think that a thermostat could be installed inside the cab and with a little wiring the compressor could be engaged/disengaged via the thermostat. This would be after someone installed a shutoff valve in the truck. I wonder if the new trucks use this same air conditioning control (or better, lack of control) as the earlier models?
  #119 (permalink)
Old 05-18-2007, 01:38 PM
Quote:
Well, that explains another mystery. I had about a 200 mile round trip to Wash DC yesterday to get an emergency implant on a front tooth #7 which I broke off when crawling around under my truck, and I raised my face up and smacked my teeth on a cross member. For a lot of the trip it was cool enough to just use the vent for outside air, but after we got to town I switched to MAX A/C to shut off the outside air due to all the traffic fumes, and that's when I noticed that no matter how I adjusted the knob the A/C wouldn't shut off.
__________________
  #120 (permalink)
Old 05-18-2007, 04:15 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
My 2000 Ranger worked that way in Max -- it had the vacuum valve that shut off the flow of hot coolant to the core and Max was just that -- **FRIGGIN' MAX**. When I put a thermometer in the output vent, I was seeing 35*. If you wanted to adjust the temp, you had to go to one of the other settings...
__________________
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
