Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 05-04-2007, 05:12 PM
dzzavid dzzavid is offline
dzzavid is starting off with a positive reputation.
For future reference NAPA has the same part
NAPA PN: 6601294
__________________
Dave
99 (early) F250 4x4 Ext Cab Auto
5 inch exhaust
DP Tune 80 tow 80 econ 140 smoke
Snow Performance Boost Charge Cooler
AFE stage II intake
CC mod
  #92 (permalink)
Old 05-12-2007, 11:54 AM
powerstrokr01 powerstrokr01 is offline
powerstrokr01 is starting off with a positive reputation.
need help
need help where do you tap into the red line at? before the junction or after?
  #93 (permalink)
Old 05-12-2007, 12:11 PM
sandlapper sandlapper is offline
sandlapper is starting off with a positive reputation.
I did the white line. Don't think it would matter much as to what side. If you are looking at that white plug with all the lines going in I tied in closest to the actuator.
__________________
2002 F-250 4x4, 4" inch exhaust, Superchips, WW, CCV and intake mod., gear vendors OD and more.
  #94 (permalink)
Old 05-12-2007, 12:34 PM
Quote:
off topic, but sandlapper, what kind of mileage do you get on the highway with you gear vendor?
__________________
Dave
5 inch exhaust
AFE stage II intake
CC mod
  #95 (permalink)
Old 05-12-2007, 05:09 PM
Best I have gotten is 18.5 mpg. I bought it more for pulling than anything. It is great in 3 over through hilly even mountainous areas. I don't run it much with the 110 hp program in and it seems as though it gets better with that. I don't run because I am pulling most of the time. Wish I had gotten a flip chip now.
__________________
  #96 (permalink)
Old 05-13-2007, 09:39 AM
With this mod, do we need to bleed the coolant system at all after doing it? i plan on tackling this project today along with the CC mod
__________________
Dave
5 inch exhaust
AFE stage II intake
CC mod
  #97 (permalink)
Old 05-13-2007, 12:13 PM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE.
I just installed a manual valve here, and first I removed the coolant cap to relieve any residual pressure, and I was able to cut the hose and install the valve without the patient losing more than a few drops of green blood!
__________________
2005 Freightliner ext cab M2 Mountain Master RV Puller, CAT C7 300 HP, 6 speed Allison TRV3000, air locker 4.33 diff, Michelin 255/80R22.5 LRG tires, pulling a 2008 40' triple axle HitchHiker.
  #98 (permalink)
Old 05-13-2007, 04:59 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Quote:
Nope, no bleeding necessary...
  #99 (permalink)
Old 05-13-2007, 11:18 PM
great thanks for the help
__________________
Dave
5 inch exhaust
AFE stage II intake
CC mod
  #100 (permalink)
Old 05-14-2007, 09:46 AM
tamte65 tamte65 is offline
tamte65 is starting off with a positive reputation.
Yep, and don't run the engine too hot before you cut the tubes.
The Green blood gets hot too, and creates some pressure into the system. The cooler the engine, the better for you to work inside the "engine room".
__________________
Stroking South Texas
F250 -00 PSD 4x4 CC SB Lariat A/T, 151k.
  #101 (permalink)
Old 05-14-2007, 11:33 AM
h2guy h2guy is offline
h2guy is starting off with a positive reputation.
Guys, I'm not downplaying any of these mods or trying to take sales away from a sponsor, but........
I remember a manual knob on the dash that opened/closed the hot water line to the heater core but can't remember which car this was on. It allowed you to regulate the amount of hot water so as to control the temps in the cabin.
It seems like there ought to be a cable operated on/off water valve out there that can be tied into the hot supply line to our heater cores. (Like a choke cable/knob)
I don't know how to research it to find what I remember but I gotta believe its out there someplace.
Would beat having to lift the hood to turn the valve on/off all the time.
  #102 (permalink)
Old 05-14-2007, 11:35 AM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
Quote:
That is why people who had the manual valve are buying the one from dieselsite. It is vaccuum controlled.
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #103 (permalink)
Old 05-14-2007, 11:57 AM
Quote:
Yeah, I know. I've gone thru this whole thread, but like some others, don't care for introducing another point for a vacuum leak.
With me, its always the KISS principle.
  #104 (permalink)
Old 05-14-2007, 12:27 PM
empiretc's Avatar
I hear that. I had the manual valve for a long while, but popping the hood when its really cold out is a pain. Not to mention, the valve wouldn't always turn so easy.
One thing I am interested in, is the fact that in 2002 (i think) and on they, ford starting putting this vacuum valves in. I wonder what exactly it would take to adapt an OEM one to the older trucks.
__________________
  #105 (permalink)
Old 05-14-2007, 01:41 PM
steve81 steve81 is offline
steve81 is starting off with a positive reputation.
Mine blows ice cold even in 100 degree weather. I bought my '02 used and have checked to see if the mod had been done, but I didn't see anything so I'm assuming Ford had fixed the problem in '02? Even on really hot days, I rarely turn the A/C fan past the second mark.
__________________
2002 F-350 Lariat CC Short Bed 7.3L 4x4
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
