Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 04-24-2007, 11:09 PM
Chance_Thomas's Avatar
Chance_Thomas Chance_Thomas is offline
Chance_Thomas is starting off with a positive reputation.
I did this mod it works great.
http://www.dieselsite.com/index.asp?...PROD&ProdID=21
__________________
2000 Ford F250 XLT 7.3L 4X4 Lariat, Garett GTP38R ,DP Chip, BTS VB, 6637 Filter, 55 Gal combo\tool , Tri Pod AutoMeters Gauges, 315's Bighorn Maxxis, 4" Lift ,HPX Crossover and 4" MBPR Exhaust
  #62 (permalink)
Old 04-24-2007, 11:48 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
WOW, the dieselsite changed their product?? I ordered one from them a few months back, but it sure doesnt look like the one they advertise now. This one looks better.
EDIT- looking back at previous posts in this thread, it was in december. post #26.
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #63 (permalink)
Old 04-25-2007, 12:04 AM
jtharvey's Avatar
jtharvey jtharvey is offline
Lost Soul
jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all
That one does look quite a bit different! I wonder why the change? I guess an email to Bob is in order.
__________________
Jeremy
See My Webshots for pics.
  #64 (permalink)
Old 04-25-2007, 01:29 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
I'm with you guys. I'd like to know if something was wrong or faulty in design with the old kind, and if we need to change to this new one to prevent some problem in the future.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #65 (permalink)
Old 04-25-2007, 01:47 AM
fixnair fixnair is offline
fixnair is gaining momentum as a positive member of FTE.
I did mine today also. I am a little disappointed with the way it works though. It does shut the water off in "vent, A/C and Max A/C but it also shuts the water off in Bi-Level, the first option to the right of off. Thats the one I use mostly for heating the cab up in the morning.
I think I am going to do away with using the red hose and install a switch on the dashboard to control the vacuum to the water control valve so I can turn it on or off at will.
Steve
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
  #66 (permalink)
Old 04-25-2007, 02:01 AM
empiretc's Avatar
I wonder if we can get some trade in credit or something if they found a flaw in the old design. I did notice the vacuum pump kicking on more often when I installed the ds valve, but didnt think too much of it since there werent any leaks in the lines.
__________________
  #67 (permalink)
Old 04-25-2007, 02:02 AM
2000 Ford F-350
Hmmm, I remember using the white hose.
Why the red?
Pop
__________________
Email SpringerPop
  #68 (permalink)
Old 04-25-2007, 05:58 AM
62trvler 62trvler is offline
62trvler is starting off with a positive reputation.
I also purchased one a while back and it was just an all black plastic valve. I don't remember where I got it from but I am not gettting that ice cold feeling. Maybe I hooked it up to the wrong vacume line???? I need to take another look at it I guess. Maybe even try the manual shut off and see if it makes a difference. Does anyone have a good supplier for the manual valve and does it need the hose fittings on the ends or is it made to just slip on?
__________________
2001 F-350 crew 4X4 LB Auto/ kwik mod, 4"exh, Dp tuner, AC mod, SS HPX, Auto Meter Gauges, AIH Delete
  #69 (permalink)
Old 04-25-2007, 09:17 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Quote:
Why the red?
Pop
If I remember correctly Pop (and that is a gigantic IF!!) the white hose cut the flow just for air conditioning settings and the red cut it for vent and air conditioning.
  #70 (permalink)
Old 04-25-2007, 11:12 AM
empiretc's Avatar
I remember the directions said use the white. Doubled checked, and yes, I used the white.
As soon as I get a new vent thermometer, i will see about running some test to really find the difference between this and the $2 manual valve.
__________________
  #71 (permalink)
Old 04-25-2007, 12:13 PM
countrycar's Avatar
countrycar countrycar is offline
countrycar is gaining momentum as a positive member of FTE.
This is a great mod. I read this yesterday and was thoroughly impressed. so much so that I bought it right away. I'm I beautiflul sunny Southern Ca Yeah,( BS).... Well the weather's nice. It doesn't get to hot here just a couple of weeks in July it hits 100-103 in the day but the mod is still nice to have. Better to have it and not need it, than to need it and not have it. I do go home to Texas quite a bit though and it does get hot there. Whew!!! I'll let yah know how it goes after the install. Thanks you Guys for this mod..Carlos
  #72 (permalink)
Old 04-25-2007, 03:21 PM
nightskyisme's Avatar
nightskyisme nightskyisme is offline
nightskyisme is starting off with a positive reputation.
Your $2.00 manual valve gets you what you paid for it....having to get out on a cool summer night because you want a little heat is a pain in the back (if you can even reach it on the side of the road).
I have no problem spending the additional few bucks to have it function automatically.
I am also in the process of installing an A/C compressor cut-off switch for the times I don't wan't the compressor running (like in defrost, floor/face, etc) along with a bi-color LED that will glow green when the A/C is on, and blue when the actual compressor is spinning.
__________________
2001 F-350 SD, 7.3, 4x4, extended cab, auto, plow, LED lighting in and out, SCT "street" programmed, smokie head and turn lights, A/C override, custom LED light bar, and more to go....
  #73 (permalink)
Old 04-25-2007, 03:24 PM
empiretc's Avatar
Jeremy, have you emailed Bob?
__________________
  #74 (permalink)
Old 04-25-2007, 06:42 PM
The red hose shuts off the water in the Bi-level, vent, A/C and Max A/C. The white hose shuts the water off in Max A/C only. By the way I went to pep boys and bought a heater valve, 6' of 5/8 heater hose and 6' of 1/8" vacuum hose for $25.00. Worth it for me.
__________________
  #75 (permalink)
Old 04-25-2007, 10:15 PM
tamte65 tamte65 is offline
tamte65 is starting off with a positive reputation.
Quote:
Yep, I bought that on Monday. It is getting "warmer" here in South Texas, 96F today in shadow. When I jumped to the car after the work 4:30pm, the console showed 115F! And my car has covered parking. Definetely needing this mod into action.
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
