Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 03-29-2007, 03:52 PM
pastormiketkd's Avatar
pastormiketkd pastormiketkd is offline
pastormiketkd is starting off with a positive reputation.
I did the mod as described in the original post about a year ago. I replaced a shut off valve in the heater inlet hose with the valve out of the Ford Ranger. I didn't like the water and coolant sitting in the heater core uncirculated for 8-9 months out of the year and this valve lets me open up the core and circulate the water from the drivers' seat.
It does a great job of making the vent, AC and Max AC settings much cooler and more efficient. I have to be careful on the highway unless its really hot outside or the AC is too cold (which is a great problem to have south of Houston on the Gulf Coast).
Personally, it was a very easy and great mod for me. Lots of ways to do this but I do like this one!
__________________
00 F450 CC 2wd, 4 in. Turbo back, DP 4 Pos. Chip, CCV, AIH delete, 4637, 6.0 tranny oil cooler and 6.0 intercooler.
  #32 (permalink)
Old 03-29-2007, 04:04 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
So my '02 already has the cut-off valve when Max AC is selected. When you go to any other setting, it opens the valve, so there's no issue of coolant sitting in the core for 8-9 months unless you never take the selector switch off Max AC (assuming the valve closes completely, of course). So far, no complaints about my AC (on Max) either. However, I read somewhere that the stock valve doesn't close it off completely -- is that true??
__________________
  #33 (permalink)
Old 03-29-2007, 04:13 PM
ernesteugene's Avatar
ernesteugene ernesteugene is offline
ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE. ernesteugene has a good reputation on FTE.
I've probably only used my heater a dozen times in the past 8+ years. The approach suggested by Markadeck of "just stopping it at the inlet and calling it a day." would be the easiest for me. Does anyone see any problems with this approach if I can remember to open the cut off valve and run the heater a couple of times a year to flush it out?
__________________
2005 Freightliner ext cab M2 Mountain Master RV Puller, CAT C7 300 HP, 6 speed Allison TRV3000, air locker 4.33 diff, Michelin 255/80R22.5 LRG tires, pulling a 2008 40' triple axle HitchHiker.
  #34 (permalink)
Old 03-29-2007, 04:15 PM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE.
I don't think it'll cause any problems, Ernest. Plenty of folks run it that way, with just a simple manual cutoff valve.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #35 (permalink)
Old 03-29-2007, 04:33 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Diesel Site says that the stock setup on the 99-03 7.3's and 03-06 6.0's does not shut off completely. Also, the setups in the Excursions are reportedly "shut-tight" configurations.
http://www.dieselsite.com/index.asp?...RODGROUP&ID=15
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #36 (permalink)
Old 03-29-2007, 04:44 PM
John311t John311t is offline
John311t has a good reputation on FTE. John311t has a good reputation on FTE.
Is this the reason why when im parked and i have the it on max ac the air goes cold then warm then cold then warm etc.
__________________
99 F-350 CCLB 4wd lifted
05 F-250 RCLB 2wd, soon to be lowered
04 GTO<---RIP, you were an awesome car.
  #37 (permalink)
Old 03-29-2007, 04:50 PM
F250_'s Avatar
2002 Ford F-250
Sounds like that might be correlating with either your compressor kicking on and off or the thermostat opening and closing on the engine... I would guess the latter of the two.
  #38 (permalink)
Old 03-29-2007, 05:14 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
1%er
2002 Ford F-250
Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of
That's it. I am ordering the DieselSite kit and doing this right after my tank mods in a couple of weeks. Anyone that lives anywhere near Houston (I am 30 miles north) knows how important and how much of a good friend cold A/C is. You sold me. No such thing as "too cold".
Thanks.
__________________
Scott
'02 F-250 SC SB 7.3L 4x4 w/ 4" SuperLift, 315/75 R16 Toyo Open Country M/Ts, Bilstein 5100s - 6 position DI tuner, AFE Stage II w/Dry S Pro, HPX, 203* Billet, CCV, Sonnax, Tru-Cool, Fumoto, ZooDad, Brite-Box, 4" MagnaFlow SST, ITP OBA, A/C comfort mod!, Autometer Z series gauges, Scan Gauge II, Tough Country bumpers
  #39 (permalink)
Old 03-29-2007, 05:29 PM
F250_'s Avatar
2002 Ford F-250
Hey Scott... I lived for 9 years in Beaumont and drove an old '85 F150 25 miles to work and back every day. Problem was that the truck came from the factory with no air conditioning at all. Believe me, I know the value of cold air in SE Texas summers. I'm going to do mine when I do my water pump in the next month or so (assuming the pump lasts that long).
__________________
  #40 (permalink)
Old 03-29-2007, 05:37 PM
1%er
2002 Ford F-250
Hey Pete!
We make the run to Beaumont occasionally for Cory Morrow shows downtown. Also go through there on our way to Lake Charles for weekend getaways.
Can't imagine not having A/C in SE Texas.
__________________
Scott
  #41 (permalink)
Old 03-29-2007, 06:29 PM
Lots of ways to skin this cat - the key is keeping the hot water out of the AC airflow however you're most comfortable. I didn't know about the dieselsite valve and I like the Ford Ranger valve I put it. I've also done it with just shutting off the hot water like I said.
But like the rest of the guys in the south, no AC is too cold when its 100 degrees and 100 percent humidity. Gotta have a good AC and big glass of iced tea.
__________________
  #42 (permalink)
Old 03-29-2007, 10:14 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
Guys, the $2 manual valve works great. I used it for 2 years and never had a problem. But my 3 year old would ask me to turn on the heater in the 50ish weather, when I normally am perfectly fine. The inconvenience of having to tunr the vlave on and off really made spending the $40 for the dieselsite valve a no brainer.
If you are gonna do it, I have to say to just so it right the first time. Get any kind of valve that is vacuumed controlled with your panel. That way you only have to pop the hood when YOU WANT TO.. LOL!!!
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #43 (permalink)
Old 03-30-2007, 12:17 PM
yamaguy's Avatar
yamaguy yamaguy is offline
yamaguy is gaining momentum as a positive member of FTE.
YOU COULD USE THE VALVE KIT FROM DIESEL SITE (oops caps) and just tap it into the vacuume line that nlemerise used with his system. I think that I'll go the autozone route and save a few $.
__________________
Dale PAA #47
03 F-350 XLT cc LB 4x4 7.3 psd 306,000 MI 9' 2" BOSS Ploy Vee
99 F-350 7.3 4x4 8'-5" Western
97 F-250 XLT Extend-cab 4x4 7.3 130,000
  #44 (permalink)
Old 03-30-2007, 11:10 PM
MATTRESS GUY MATTRESS GUY is offline
MATTRESS GUY is starting off with a positive reputation.
i did this mod and it is great!!! the reason u cant use just the two dollar shut off is because some mornings u need heat and in the same afternoon u need air, also they told me that the coolant would stagnate sitting in the core for 6 or seven months..
i have a digital thermometer that stays in my vent and sometimes idling it gets as low as 39.1 degrees.. before it only got down to around 53.6 degreees
it is not hard at all to do this mod...
here it is.......
http://www.forgotton.net/diesel/heaterbypass/index.htm
trust me this works and it took me about twenty or thirty minutes to do
i bought the valve on ebay for around seven dollars
the whole thing probably costed less than twenty, maybe even fifteen
  #45 (permalink)
Old 03-30-2007, 11:18 PM
make sure you get 5 feet of 1/8 in. vacumm line, an 1/8 in. tee, and get a pack of the little rubber adapters to fit different size vaccum lines ask for them at auto zone, cause you'll need em.. 4 5/8 hose clamps
i folded the glove box down and cut the red vacuum line and teed it there...there is a little rubber plug that goes thru the firewall in the far right corner just above the carpet, poke a hole in the plug and feded the line thru it, then just fish it right up there where you need it...
this is probably my favorite mod that ive done, but i like teeth breaking ice cold air
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
