Wow...REAL Air Conditioning!! - Page 26 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #376
Old 06-11-2013, 11:37 PM
B_Allen B_Allen is offline
B_Allen is gaining momentum as a positive member of FTE.
What size are the heater hoses? I'm thinking a 5/8 fitting into a ball valve on each hose.
  #377
Old 06-11-2013, 11:46 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Quote:
Originally Posted by SpringerPop View Post
Excursions came with this valve from the factory, so it already has one and can't be improved-upon.
It's us F-Series drivers that see improvement by adding Excursion parts.
Pop
You know I was wondering about this and do know my X has the valve. But I was wondering because on hot days the air coming threw the vents as quite a bit warmer than ambient temp.
  #378
Old 06-12-2013, 12:11 AM
Budman1962's Avatar
Budman1962 Budman1962 is offline
Budman1962 is starting off with a positive reputation.
Quote:
Originally Posted by cutlass View Post
Does anyone know the Ford part number for the appropriate Excursion valve that we can use in our trucks?
Thanks,
Drake
motorcraft YG366. The cheapest price I found is amazon
  #379
Old 06-12-2013, 12:20 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
There are others, but that's the one I put on years ago, and it's still playing a good tune.
I'd recommend it for longevity.
Pop
  #380
Old 06-12-2013, 01:13 AM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
Quote:
Thank you for that part number!
Drake
  #381
Old 06-12-2013, 02:49 AM
empiretc's Avatar
empiretc empiretc is offline
empiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to all
ranger valve.... $12
  #382
Old 07-16-2015, 08:12 AM
Supercab Supercab is online now
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Thought it was a good time to resurrect this thread for those that need their a/c colder for the hot, brutal summer!
  #383
Old 07-16-2015, 12:22 PM
husker's Avatar
husker husker is offline
husker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud of
I just shut the valve on mine a couple of days ago. It made a big difference. I just used a single inline valve and close it manually. It takes about a minute to open the hood and flip it closed.
  #384
Old 07-16-2015, 01:03 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
I bought a plumbing valve at Lowes for PEX tubing, and the OD of the fittings (integral with the valve) was just right for the Ford heater hose. I also open the valve a few times a summer with the engine running, to let fresh coolant circulate thru the heater core.
My AC center vent temp the other day was 43F, and it was 78F outside. From my testing, adding this shutoff valve didn't make a huge difference, but every bit helps.
  #385
Old 07-16-2015, 08:04 PM
I chose to install the Ranger valve and tap the vacuum line YEARS ago, and I notice a BIG difference!!
-Haven't seen the OP on in a while...anyone know him??
  #386
Old 07-16-2015, 08:28 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
I've had the PEX ball valve in mine since 2004, but lately I've been thinking about a vacuum valve with a toggle valve in the dash so I have easier control over the water flow.
  #387
Old 07-16-2015, 09:59 PM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
So, am I reading right that just one valve on the inlet line does the trick? Wouldn't this cause a backup and block flow? Which hose is the inlet hose? If it I am understanding right and it doesn't cause issues, I'll be doing this tomorrow.
  #388
Old 07-17-2015, 01:20 AM
Quote:
Yes, I do. Neal's still around, just not as active here since he bought a forty-foot Class-A, and spends half his year in Mexico on the beach!
But we still correspond.
Good guy!
Pop
  #389
Old 07-17-2015, 10:47 AM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
that flow is more like bypass so no problem blocking that flow.
  #390
Old 07-17-2015, 11:13 AM
Quote:
Ah, makes sense. I am guessing the one closer to the driver's side is the inlet? I haven't looked at it real close yet. I guess I need to get my butt out there and pop the hood.
Help a blind man to see...vacuum line problem. nlemerise 1999 - 2003 7.3L Power Stroke Diesel 8 08-07-2016 11:08 AM
Stumped..97HD 460 gets hot accelerating foxboss9 1999 to 2016 Super Duty 17 05-25-2016 03:53 PM
No air blowing from floor vents IIGood Explorer, Sport Trac, Mountaineer & Aviator 6 01-21-2016 07:12 PM
Simplifying the Vacuum System of a 390 crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-24-2015 11:09 AM
heater core shutoff done and pics! abendx 1999 to 2016 Super Duty 10 06-09-2003 07:34 PM
Tags
512209, 74809, 920001, ac, air, compressor, conditioned, conditioning, ford, heater, number, seat, solenoid, trans, truck, vacuum, valve, wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
