Wow...REAL Air Conditioning!!
#346
the kit runs just as it would had it been installed at the factory. I am using a stock ac/heater box now. This is where I am abit confused, I did the install 6 months ago and I dont remember if the air is forced to go through the heater core like it is in all the trucks you guys are talking about here.
#348
#349
I now that this topic and thread have been beaten to death but......
Just to play devil's advocate (and I don't claim to know the thermodynamic properties of all of the cooling system), if you shut off the water/coolant passage from the engine to the heater core in order to see better A/C temps, doesn't that effectively raise the engine temp in one part of the engine since you are trapping hot water in that particular area?
#351
#353
The heater core is similar to the coolant filter kits you can add, they're small bypass systems. In theory, you'll loose a tiny amount of "engine cooling" by blocking it off, but nothing you'd notice. Its not gonna keep any hot coolant from making its way to the radiator. In fact, it'd take a more direct route with it closed.
#354
#355
#356
#357
-Guys, PLEASE don't bash me for resurecting this thread.
I did this mod about 3 years ago on my LATE '99 F350 Dually, I tapped into the RED vacuum line behind the glovebox, this RED line causes the new Ranger valve to close when your controls are on anything on the LEFT side of "off"
Mine has worked perfectly up until last week when I noticed the normal outside (vent) air was actually warm.
I checked the valve, and apparently the diaphram in it has gone bad already.
I think the valve I bought brand new from AutoZoo was all plastic and from a company called "Factory Air"
I am wondering IF a FACTORY FORD valve (for a Ranger) would be any better than the one from "Factory Air"
BTW, I have forgotten, what year Ranger do I need to ask for the valve for??
-Just found THIS:http://www.ebay.com/itm/HEATER-CONTROL-VALVE-Ford-Explorer-Ranger-Aerostar-NEW-/200464464163?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1999%7CModel%3ARanger&hash=item2eac9cf923&vxp=mtr#ht_2599wt_1086
Is this the right valve?? They are saying its a FACTORY FORD valve........
#358
#359
Marv,
Do you or anyone else know the part number of the Excursion Heater control valve from Ford that works best on our trucks? I looked on Ford's parts website and it looks like at least 4 different part numbers for different Excursion applications.
Any help is appreciated.
Thanks,
Drake
