Once you start operating the valve while checking out the functionality, you probably let some hot coolant through the system and it doesn;t take but a minute or so to fill the core with hot coolant. I saw the same thing on mine this past weekend. The only way to check for sure is:
1. leave the setting in Max A/C when you shut down the truck
2. let it sit overnight so all heat is dissipated
3. start up the next morning LEAVING the setting on Max A/C, and THEN
4. check the core side temperatue.
If you get hot temps after the valve (several inches downstream) after following the above steps, the valve is NOT holding.
