Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #301 (permalink)
Old 07-01-2009, 03:16 PM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
1999 Ford F-Super Duty
N V US Lawn Care is starting off with a positive reputation.
Well, this is now on my todo list...hahaha, dang PMS, wheee...this along with the A/C spacer mod and I think the A/C will cause icicles on the ears...looking forward to doing this one...so are my wife and kids. They got tired of the A/C getting warm every 20 minutes on our last trip, and secretly, so did I.
  #302 (permalink)
Old 07-01-2009, 07:57 PM
chayes01's Avatar
chayes01 chayes01 is offline
chayes01 is starting off with a positive reputation.
Quote:
What's the A/C spacer mod? Did a search and haven't found it. Did the diverter mod and it works great.
__________________
2001 F350 4x4 Crewcab, 6 spd manual trans.
Mods: 6637, IAH delete, Zoodad, CCV, HPX, 4" S.S. MagnaFlow Turbo back exhaust, ISSPRO gauge set (EGT, Boost, Trans. temp), Dieselsite fullflow external trans filter, Dieselsite bypass coolant filter, AE. DP Tuner. RiffRaff 6637 Prefilter.
  #303 (permalink)
Old 07-01-2009, 08:19 PM
mxdadof2's Avatar
mxdadof2 mxdadof2 is offline
mxdadof2 is gaining momentum as a positive member of FTE.
Quote:
Read through this thread and it will help you. Basically what you are doing is checking the gap of the clutch on the compressor. It should be between .25 and .30 . It is about a 20 minute fix and will have the air blowing super cold. There are shims that may need to be removed to get your gap to this, but do make sure that the clutch engages and disengages or will cause damage.......
http://www.ford-trucks.com/forums/86...ic-in-dfw.html
__________________
Ron- 01' 7.3 PSD EC 4x4 no mods yet... but working on those.....
PAA Member #80
Mississippi Chapter Member
  #304 (permalink)
Old 07-01-2009, 11:05 PM
Bossman7121's Avatar
Bossman7121 Bossman7121 is offline
Bossman7121 is starting off with a positive reputation.
Great stuff ! Mines already cold but I am having an issue whent he system is on the lowest setting ( blower no workie... ) Only works from 2nd and up. Any fixes?
__________________
2000 F250 SD 7.3,
Mod's Listed in Gallery
FTE
http://www.rmgmiami.com/mikes_truck_pics.htm
  #305 (permalink)
Old 07-02-2009, 02:30 AM
danyzf95 danyzf95 is offline
danyzf95 is starting off with a positive reputation.
Replace the resistor block for the heater blower motor on the passenger side fire wall. Good chance when you pull the resistor block out you will find a blown resistor.
  #306 (permalink)
Old 07-02-2009, 05:16 PM
kupaa's Avatar
kupaa kupaa is offline
kupaa is starting off with a positive reputation.
if i put that ball valve on will the temp control work? and what size is the valve?
__________________
2002 F-250 SC 4X4-AUTOMETER COBALT GAUGES EGT,BOOST,TRANS, AFE STAGE 1 INTAKE,SILVERLINE 4INCH TURBOBACK STRIGHT PIPE EXHAUST,ITP OVERBOOST ANNIHILATOR,WICKED WHEEL, DP TUNER, BTS VALVEBODY,FOIL DELETE,BANKS BIG HEAD WASTEGATE,203*STAT,BILLET HOUSING.
_______________
Chris
http://i243.photobucket.com/albums/f...aa26/010-2.jpg
  #307 (permalink)
Old 07-02-2009, 05:21 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
I don't believe so. The temperature is controlled by regulating the flow of hot coolant to flow through the heater core.
The problem this mod deals with is that the stock valve does not chut off completely when you're trying to get the msot from your system. A manual valve takes away the temperature control's ability to regulate the coolant flow altogether, that's why a vacuum-actuated valve is recommended for use with the MAX A/C white vacuum line... this let's the regular A/C and Vent and Bi-Level settings retain control over the stock regulating valve.
Once you've installed a manual ball valve, the regulating valve can move all it wants to but the manual valve will not let the coolant flow, so your temperature control cannot function at all.
The thread linked below provides you with a summary document of what this thread contains, and it might be easier to trace out the issues there.
http://www.ford-trucks.com/forums/86...materials.html
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #308 (permalink)
Old 07-02-2009, 11:18 PM
Hey guys, Clay told me that the part from DieselLite, that's $47 bucks can be purchased at any auto parts store for less money...it is a common part for a ranger, not sure what the part number(s) are, but i am so confident in these folks on FTE, that i know somebody does...
  #309 (permalink)
Old 07-03-2009, 01:29 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Autozone #74809 heater valve
  #310 (permalink)
Old 07-03-2009, 06:42 PM
MJScore's Avatar
MJScore MJScore is online now
MJScore is starting off with a positive reputation.
Does anyone have a picture of the location of the red and white vacume hose to tee off of? I've looked behind my glove box and only see a white line.
  #311 (permalink)
Old 07-03-2009, 10:03 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
If you follow the black and white lines you see back toward the center of the truck, you'll see a plug that has several color vacuum lines (they look more like wires). Once you lower the glove box, just look to the left.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #312 (permalink)
Old 07-03-2009, 10:13 PM
MJScore's Avatar
Thanks F350-6, I'll get going on this mod first thing in the morning when it's cool outside.
  #313 (permalink)
Old 07-03-2009, 10:28 PM
Moddin for RR East...
I went and got the items listed for this mod today, everything cost $24 at Advance Auto...i got pics of the stuff for everybody, will be installing tomorrow or Sunday, depending on how long my other mods take...hahaha...
On a different note, i want to attach images to my posts, but really don't know how...am i just that illeterate?????
  #314 (permalink)
Old 07-03-2009, 10:39 PM
F350-6's Avatar
Slow Typing
Probably
I'm not a computer genius, but the 2 methods I know how to use are either to use the "Manage Attachments" button in the advanced reply option, or the easier way is to upload the photos into your gallery. Then open the gallery in a separate tab and select the picture you want to insert. If you right click the picture you want in your thread you can select something that says "copy image location" or something similar. I use Firefox so that's the option I get. Then go back to your post and click on the little envelope looking thing that looks like this A little window pops up and you just paste the image location you copied earlier into that pop up. Hit OK and you've got a picture in your post.
We do have a testing section in the forum here where you can practice doing this. Feel free to use my gallery if you want to try and figure this out.
__________________
Chris
  #315 (permalink)
Old 07-04-2009, 12:32 AM
Thanks brother, i will play with the testing section and see if i can post a pic of my new gadgets....did you get the chance to look at my garage yet???If not take a peek and critique my mod work...hehehe...later Chris
David
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
