Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #286 (permalink)
Old 06-20-2009, 10:49 AM
Budman1962 Budman1962 is offline
Budman1962 is starting off with a positive reputation.
If I just put in a ball valve which line should it go in?
Thanks
Budman
__________________
When the drive is through this Buds for you!
2000 F-250 V-10 SWB CC
98 yamaha GP1200 WaveRunner
2000 Polaris Genesis
94 Kawasaki ST750 Jetski
06 Polaris 500 X2, 86 Honda Magna
  #287 (permalink)
Old 06-20-2009, 12:45 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
It shouldn't make any difference.
If hot coolant can't get IN to the core, it stays cool.
If coolant can't get OUT, nothing can get IN either, and the core stays cool.
In or out, blocked flow is blocked flow.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #288 (permalink)
Old 06-20-2009, 01:10 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
best bet is to spend the $12 and get that ranger cutoff valve. It is vacuum controlled and cuts off both lines!
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #289 (permalink)
Old 06-20-2009, 07:02 PM
We don't have an autozone around here. Any idea if I can get the ranger valve from napa or oreilly's . What year did they come on the ranger?
Thanks,
Budman
__________________
  #290 (permalink)
Old 06-20-2009, 07:37 PM
empiretc's Avatar
i am pretty sure you will be able to get it at oh-rye-lees. it covers quite a few years on the ranger/epy, etc.. Go in and ask for one, it will look like this:
__________________
  #291 (permalink)
Old 06-20-2009, 08:31 PM
crum71's Avatar
crum71 crum71 is offline
1/8 mile Oval Track
crum71 has a very good reputation on FTE. crum71 has a very good reputation on FTE. crum71 has a very good reputation on FTE. crum71 has a very good reputation on FTE.
I put mine in the hose that has the wire loom stuff on it. When I cut it,there wasn't any leaks. Benn that way since last summer with no issues at all.
Quote:
Thanks
Budman
__________________
Scott PAA #60 2000 F250 7.3 Lariat Auto 4x4
Quote:
Originally Posted by Markadeck
I love each and everyone of y'all.
01-23-2009, 08:58 AM
  #292 (permalink)
Old 06-21-2009, 12:21 PM
husker husker is offline
husker is gaining momentum as a positive member of FTE. husker is gaining momentum as a positive member of FTE.
How hard is it to add a vacuum switch that can be operated manually that is separate from the air/heat switch?
__________________
Del
2001 F250 SD PSD 4x4
78 Bronco
54 F250
48 F5
64 Thunderbird
  #293 (permalink)
Old 06-21-2009, 01:23 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is online now
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
This is the valve I got from the dealership, yes the dealership.
It was 25 dollars and cheaper then Autozone or Checkers/O'rielly's.
List price was 27 dollars but the parts guy took a couple bucks off.
Here is a Photobucket LINK to my install.
I teed into the red line and the valve closes in Max AC, AC, Dash outlets and Dash and Foot well outlets position. Works normally when in the Foot well only, Foot well and Defrost, or Defrost only posotion. You can tee into the white vac line to have the valve close in only the Max AC position. Once it starts getting cool I can remove yellow vac line and cap the tee and the HVAC system will work as stock.
  #294 (permalink)
Old 06-21-2009, 02:16 PM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a good reputation on FTE. spdmpo has a good reputation on FTE.
Thanks for that part number. $16 at Amazon:
Amazon.com: F87Z18495AA VALVE: Automotive
I'm going to give it a shot and see if it helps.
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #295 (permalink)
Old 06-21-2009, 04:48 PM
PaysonPSD's Avatar
Support FTE
Your welcome Keith. That's a good price. I never thought of Amazon.com.
  #296 (permalink)
Old 06-28-2009, 02:24 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 is gaining momentum as a positive member of FTE. Bigcat350 is gaining momentum as a positive member of FTE.
I just completed this little mod and it works great. Its blowing ice cubes now.
Got the valve at Auto Zone for $17.99, 5 ft of 5/32 vacuum line and 4 1-1/16 clamps I had the T. Total cost $25.48. I used Joe's fishing line and sinker trick to pull the vacuum line up the back side by the fender then slide the red wire loom on. I also remove a shim from the clutch. So it should all be in good shape for a while.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #297 (permalink)
Old 06-28-2009, 03:13 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Good deal -- whatever works!!
__________________
  #298 (permalink)
Old 06-28-2009, 06:55 PM
big poppa's Avatar
big poppa big poppa is offline
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
So without going back and reading, I think I have a cutoff already on the top hose going into the firewall, its teed into the hose and the gizmo looks like it vacum operated, i,m wondering if this is what everbody is talking about that the 03's already have a cutoff???I don't have a pic but it looks like a canaster with a small frisby type thing on top then a vacum port for the hose, is this my cut off to the heater core from the factory?? My air blows artic when rolling, wouldn't want to make any changes if I didn't have't to, what yaa think..???
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 131,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #299 (permalink)
Old 06-28-2009, 06:58 PM
Izzy351's Avatar
Getting Faster...
Yep -- you already got it.
__________________
  #300 (permalink)
Old 06-28-2009, 07:06 PM
big poppa's Avatar
2003 Ford F-250
Quote:
I,m glad I mentioned it, would have put on a cutoff for nothing, thanks Joe, again...
__________________
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
