Wow...REAL Air Conditioning!!
Old 07-29-2006, 10:22 PM
John7894's Avatar
John7894
John7894 is offline
Originally Posted by empiretc
a $2 manual shut off valve is just as effective.
Which hose should the valve go in? Which one is the in let hose to the heater core?
Old 07-29-2006, 10:33 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
C'mon now. I was thinking two valves. Both should be before the firewall if you're going to keep the heat out. Just one will allow transfer of heat more readily through either the supply or return. That's my .02. I was even considering a seteup that would just recirculate it back through the hoses without ever getting into the air box/heater core.
Old 07-29-2006, 11:36 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
Look at the pictures I posted earlier...the valve DOES block both hoses AND recirculates back to the engine block.
Old 07-30-2006, 09:10 AM
cangim's Avatar
cangim
cangim is offline
I used the same valve as posted in nlemerise parts list. All is hooked up and looking good. Have drove any where though since I put it in so I don't really know if it will make the A/C any cooler or not yet.
Old 07-30-2006, 12:00 PM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
I am near Houston and it is hotter than Hades here every day. Might just have to try this out.
Old 07-30-2006, 12:04 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
used hydrolic quick connects on mine . put them in opposite of one another on inlet and outlet summer time just a hot water loop,winter time nice warm heat.this requires a little more work but no in cab water or vacume leaks
Old 12-14-2006, 01:24 PM
1bigolebear's Avatar
1bigolebear
1bigolebear is offline
I am very interested in this..............I have a 2000 crew cab and it doesn't do a very good job of cooling the whole cab,........Think I'll try the cut-off valve first. Do I just find the hot water inlet and install a shut-off????????? Start it up,let it run, turn to heat, and see which one warms up first? That should be my inlet hose ,.right?
Old 12-14-2006, 02:06 PM
rad1026's Avatar
rad1026
rad1026 is offline
I wondered why the vent never lets in cool air. It's usless. Always warm air. I might try something like this just to be able to use the vent more often.
Old 12-14-2006, 02:12 PM
empiretc's Avatar
empiretc
empiretc is offline
I just took the $2 manual valve out that I installed some time back. I replaced it with the one from dieselsite. It works very well. The only reason I did it, is cuz this time of year you need the heater in the morning and the air-con by noon.
Old 12-14-2006, 02:23 PM
F250_'s Avatar
F250_
F250_ is offline
Hey empiretc, where is the valve you're referring to on dieselsite.com? I can't find it.
Old 12-14-2006, 02:27 PM
empiretc's Avatar
empiretc
empiretc is offline
http://www.dieselsite.com/index.asp?...PROD&ProdID=21
Nice item and took 15 minutes to install.
Old 12-14-2006, 02:38 PM
F250_'s Avatar
F250_
F250_ is offline
Looks great. I also like the idea of not losing all thermostat type of control with the originally proposed hookup in this thread. Sounds like a simpler install with maximum flexibility. Being in Birmingham, I don't really need toe AC right now, so I'll probably wait until about March/April to do this mod.
Thanks, empiretc.
  #28
Old 12-15-2006, 01:52 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
This "mod" is standard equipment on Excursions. I bought my vacuum-operated coolant valve from Bob Riley, but you "COULD" (but don't!) even get it at your Ford stealership.
That, combined with shimming my compressor clutch properly, completely restored my A/C system to "MAX" happiness!
I shudder to think what it would have cost if I had taken it to the "Factory-trained Ford technicians". Easily hundreds, maybe even thousands. Whew! I dodged another bullet with a Ford logo on it.
Again, the "Supporter" money you spend on joining FTE is the best investment you can make unless you're married to the governor of Arkansas.
OK, that was a cheap shot.... With a big grin, I'll take full responsibility for it.
Pop
  #29
Old 12-15-2006, 06:14 PM
hookd's Avatar
hookd
hookd is offline
GREAT INFO!!! There's alot of summer days around here that the vent would be good enough if it didn't blow hot air all the time. I can't wait to leave that fuel guzzling A/C off this summer. Best $15 bucks I ever spent thanks.
  #30
Old 03-29-2007, 02:03 PM
SCHRADE's Avatar
SCHRADE
SCHRADE is offline
Just a quik clarification. If I go the diesel site valve option, do I still get this advantage of the cool air across/out of the just vent setting?
Quick Reply: Wow...REAL Air Conditioning!!
