Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-29-2006, 11:22 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is starting off with a positive reputation.
Quote:
Originally Posted by empiretc
a $2 manual shut off valve is just as effective.
Which hose should the valve go in? Which one is the in let hose to the heater core?
__________________
John
2008 F350, 6.4, Crew Cab, King Ranch, 4WD, SRW, 62,000 miles.
2001 F250, 7.3, Crew Cab, Lariat, 2WD. 329,000 miles and counting!!
  #17 (permalink)
Old 07-29-2006, 11:33 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Quote:
C'mon now. I was thinking two valves. Both should be before the firewall if you're going to keep the heat out. Just one will allow transfer of heat more readily through either the supply or return. That's my .02. I was even considering a seteup that would just recirculate it back through the hoses without ever getting into the air box/heater core.
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #18 (permalink)
Old 07-30-2006, 12:36 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Quote:
Look at the pictures I posted earlier...the valve DOES block both hoses AND recirculates back to the engine block.
  #19 (permalink)
Old 07-30-2006, 10:10 AM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE. cangim is gaining momentum as a positive member of FTE.
I used the same valve as posted in nlemerise parts list. All is hooked up and looking good. Have drove any where though since I put it in so I don't really know if it will make the A/C any cooler or not yet.
__________________
http://www.ford-trucks.com/user_gall...id=153297&.jpg
Wishin I was still camping somewhere....
-Mike
  #20 (permalink)
Old 07-30-2006, 01:00 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
1%er
2002 Ford F-250
Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of
I am near Houston and it is hotter than Hades here every day. Might just have to try this out.
  #21 (permalink)
Old 07-30-2006, 01:04 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
NC chapter LDR
MAKO314 is gaining momentum as a positive member of FTE. MAKO314 is gaining momentum as a positive member of FTE.
used hydrolic quick connects on mine . put them in opposite of one another on inlet and outlet summer time just a hot water loop,winter time nice warm heat.this requires a little more work but no in cab water or vacume leaks
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2006 F350 6.0 not PSD, POS 4X4
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #22 (permalink)
Old 12-14-2006, 02:24 PM
1bigolebear 1bigolebear is offline
1bigolebear is starting off with a positive reputation.
I am very interested in this..............I have a 2000 crew cab and it doesn't do a very good job of cooling the whole cab,........Think I'll try the cut-off valve first. Do I just find the hot water inlet and install a shut-off????????? Start it up,let it run, turn to heat, and see which one warms up first? That should be my inlet hose ,.right?
  #23 (permalink)
Old 12-14-2006, 03:06 PM
rad1026's Avatar
rad1026 rad1026 is offline
rad1026 is starting off with a positive reputation.
I wondered why the vent never lets in cool air. It's usless. Always warm air. I might try something like this just to be able to use the vent more often.
  #24 (permalink)
Old 12-14-2006, 03:12 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
I just took the $2 manual valve out that I installed some time back. I replaced it with the one from dieselsite. It works very well. The only reason I did it, is cuz this time of year you need the heater in the morning and the air-con by noon.
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #25 (permalink)
Old 12-14-2006, 03:23 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Hey empiretc, where is the valve you're referring to on dieselsite.com? I can't find it.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #26 (permalink)
Old 12-14-2006, 03:27 PM
empiretc's Avatar
http://www.dieselsite.com/index.asp?...PROD&ProdID=21
Nice item and took 15 minutes to install.
__________________
  #27 (permalink)
Old 12-14-2006, 03:38 PM
F250_'s Avatar
2002 Ford F-250
Looks great. I also like the idea of not losing all thermostat type of control with the originally proposed hookup in this thread. Sounds like a simpler install with maximum flexibility. Being in Birmingham, I don't really need toe AC right now, so I'll probably wait until about March/April to do this mod.
Thanks, empiretc.
__________________
  #28 (permalink)
Old 12-15-2006, 02:52 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
This "mod" is standard equipment on Excursions. I bought my vacuum-operated coolant valve from Bob Riley, but you "COULD" (but don't!) even get it at your Ford stealership.
That, combined with shimming my compressor clutch properly, completely restored my A/C system to "MAX" happiness!
I shudder to think what it would have cost if I had taken it to the "Factory-trained Ford technicians". Easily hundreds, maybe even thousands. Whew! I dodged another bullet with a Ford logo on it.
Again, the "Supporter" money you spend on joining FTE is the best investment you can make unless you're married to the governor of Arkansas.
OK, that was a cheap shot.... With a big grin, I'll take full responsibility for it.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #29 (permalink)
Old 12-15-2006, 07:14 PM
hookd's Avatar
hookd hookd is offline
hookd is starting off with a positive reputation.
GREAT INFO!!! There's alot of summer days around here that the vent would be good enough if it didn't blow hot air all the time. I can't wait to leave that fuel guzzling A/C off this summer. Best $15 bucks I ever spent thanks.
__________________
HOOK
07 Expedition EL 4x4 XLT(the wife won't allow mods)
  #30 (permalink)
Old 03-29-2007, 03:03 PM
SCHRADE SCHRADE is offline
SCHRADE is starting off with a positive reputation.
Just a quik clarification. If I go the diesel site valve option, do I still get this advantage of the cool air across/out of the just vent setting?
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
