Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #256 (permalink)
Old 06-16-2008, 05:17 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
FWIW, I just used a drill and made a hole that's a bit smaller than the line and it fed right through. You should be able to sneak a drill bit in there next to the other line. I'm curious what else is run though there, though.
I then dropped a piece of fishing line with a weight attached to it down from the top side of the engine bay. It was a bit of a challenge getting it dropped down through where I wanted the vacuum line to come up, but I got it eventually. Then I just tied them together and pulled the line up and attached it to the solenoid. I think I was done with the whole job in about 30-45 mins.
__________________
  #257 (permalink)
Old 06-16-2008, 06:46 PM
Supercab Supercab is offline
Supercab is gaining momentum as a positive member of FTE. Supercab is gaining momentum as a positive member of FTE.
Wink
Its anouther vacuum line, I have no clue what its for. like I said mine is a LATE 1999 F350, anyone else have any ideas as to what this line might be for?
__________________
Support FTE
  #258 (permalink)
Old 06-19-2008, 10:04 PM
skrinar70's Avatar
skrinar70 skrinar70 is offline
skrinar70 is starting off with a positive reputation.
did this mod today, dropped the air temp from ~50 down to ~42..... a great way to spend $20
__________________
79 F150 SWB 4X4 514, c6, np205, Disc Brake 60s
99 F250 4x4 CCSB 7.3 auto
72 Harley XLCH Ironhead 1000
2000 Harley FLSTF Fatboy
2002 Peterbilt 379 C16 625hp Cat, 18 spd, 3.36s
1974 Kenworth K100, 350 Cummins 13 Spd 4.33s
  #259 (permalink)
Old 06-19-2008, 11:03 PM
Cracker 73 Cracker 73 is offline
Cracker 73 is starting off with a positive reputation.
Did this mod to day and it worked great used 2 manual cut offs under 20 bucks from NAPA and worth every cent thanks to you all for keeping post alive . I have cut offs on all my big trucks but never had a thought about it on my pick up. thanks again FTE group.
  #260 (permalink)
Old 06-20-2008, 11:59 AM
tiger94gop tiger94gop is offline
tiger94gop is starting off with a positive reputation.
I did it last night, I ran a clothes hanger through the grommet, it came out under the fan box near the passenger side firewall. I taped the hose to hanger and pulled it back through. Really easy.
2002 F-250 4-dr, 4-wd
6637, a/c mod, upgrading daily
  #261 (permalink)
Old 06-22-2008, 05:38 PM
Wink
I finished up mine yesterday, and after the 203* T-stat install I was getting about 55* out of the vents on Max, now I get 42* on the normal a/c setting!!
Very cool mod-literally!! I tapped into the RED vacuum line and now everything on the left side of off closes the valve, and the first position on the right does as well-its the floor/face vent position--this is the best for me, as I like the fresh air while riding, and not contineually the recirculated air that would be the only one that would close the valve if I were to have spliced into the WHITE line
__________________
Support FTE
  #262 (permalink)
Old 06-22-2008, 09:22 PM
kawika's Avatar
kawika kawika is offline
kawika is gaining momentum as a positive member of FTE.
I had completed the mod using the Ford Ranger valve and I find that I like the cooler vent temperatures, but on the colder days, I find that I wish I had a little more heat without having to place the selector to feet, defrost, or the combination of the two to get some heat.
So I got to thinking on what to do, How do I get the Ford Ranger valve to NOT close the heat at times. So the simplest thing to do was get a 1/8 vacuum shutoff valve that I can close so that the Ranger valve is not even in the vacuum circuit.
So what I did was I bought a valve that you push a button on the vacuum valve to close off the vacuum to the Ranger valve, and then press the valve together to open it up. It can shut off vacuum with or without vacuum towards the Ranger valve and it will hold what ever condition it was in when valve was closed. So if you close it down when the Ranger valve is operated, you will not have heat in any selction, Close down the valve when the Ranger valve is not operated and you are back to stock.
So, with a push of a button, I can get my truck back to stock condition, and then squeeze the valve, and it's back to the Freezer Mod.
Here is a chart of what it can do..
Valve OpenValve ClosedValve Closed
OEM No MODw/ Ranger Valve Red HoseWhen Ranger Valve Not OperatedWhen Ranger Valve Operated
Dash SettingHeat AvailableHeat AvailableHeat AvailableHeat Available
MAX A/CYESNOYESNO
A/CYESNOYESNO
VentYESNOYESNO
OFFYESYESYESNO
Vent/FeetYESNOYESNO
FeetYESYESYESNO
Feet/DefYESYESYESNO
DefYESYESYESNO
Here is the valve I bought..Small-Parts In-Line Shutoff Valve 1/8 " Tube..
That way I do not have to remove anything or go into the engine compartment.
Dave..
__________________
01 F250 7.3 PSD CC 4x4 Lariat Auto
Skyjacker 6" lift, 37in BFG KO
BTS Trans w/6.0 cooler
K&N FIPK w/Filter Wrap
hpx mod, 3 Gauge A-Pillar, DP Tuner
4in Exhaust Turbo back
"Gray" CPS, AIH delete
  #263 (permalink)
Old 06-22-2008, 10:42 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Dave...You ARE the man! Great job...
MAX A/CYESNOYESNO
A/CYESNOYESNO
VentYESNOYESNO
OFFYESYESYESNO
Vent/FeetYESNOYESNO
FeetYESYESYESNO
Feet/DefYESYESYESNO
DefYESYESYESNO
Dave..
  #264 (permalink)
Old 06-22-2008, 10:49 PM
big poppa's Avatar
big poppa big poppa is online now
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
Thats a cool setup, nice job.
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 132,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #265 (permalink)
Old 08-06-2008, 03:36 PM
smoky_diesel's Avatar
smoky_diesel smoky_diesel is offline
smoky_diesel is starting off with a positive reputation.
Finally got around to doing this mod. well worth the $30 and 30 minuets. took longer to read this tread than to do the job. I t'd into the white hose at the recirculating valve, didn't have to cut anything. Noticeable difference here in the summer Phoenix heat.
__________________
Justin
2000 F-250 PSD Lariat - 4" lift, 35s, DP tuner, OBA, 4" exhaust, gauges, 6637, In-tank kit, walbro 392, shimmed FPR, foil delete, 1000W stereo.
  #266 (permalink)
Old 08-06-2008, 03:48 PM
deereman4020's Avatar
deereman4020 deereman4020 is offline
deereman4020 has a very good reputation on FTE. deereman4020 has a very good reputation on FTE. deereman4020 has a very good reputation on FTE. deereman4020 has a very good reputation on FTE.
would you recomend this mod to someone who lives in wisconsin because i dont want to freeze my azz off in the winter
__________________
Jacob
Resident farmboy, King of tractors, tractorpuller and workaholic
PAA Member #63
89 F-250 XLT Lariat reg cab long bed 4X4 351 ZF5 4in lift 33in BFG ATs on 16.5 in aluminum rims
  #267 (permalink)
Old 08-06-2008, 08:17 PM
King0581's Avatar
King0581 King0581 is offline
King0581 has a good reputation on FTE. King0581 has a good reputation on FTE.
I believe I would get with Dave/Kawika and find out what kinda valve he used for his setupin addition to the shutoff valve or just t into the white line. I had mine t'd into the red line and not being able to have heat on anything left of off sucked!
__________________
Lee
"I'm hearing voices but all they do is complain"
  #268 (permalink)
Old 03-28-2009, 03:30 PM
Gcrop's Avatar
Gcrop Gcrop is offline
Gcrop is starting off with a positive reputation.
After spenidng a bunch of time going through this thread, I want to know if you guys think this might be an option for me.
Putting T's in both the red and white line and hook the valve up to one for winter/summer and cap the other one off with a rubber nipple.
I know some of you guys don't like to open the lines anymore than you have to.
If it comes down to it, I will just go with the white hose. It gets extremely hot and humid here in the Delta.
Advice?
__________________
Geoff
2001 F-250 PSD SWB CC Lariat 187,000 miles
315/75 16 BFG A/T, leveling kit, 6637, DP Tuner, muffler delete, ZooDad, ProComp ES9000 shocks
  #269 (permalink)
Old 03-28-2009, 04:19 PM
Izzy351's Avatar
Getting Faster...
If you go with the white one like I did, you'll get heat on any setting except off & Max AC. If you put it in the red line, you be set up like the little chart above.
I'm still amazed that this thread has had such a looooong life....
__________________
  #270 (permalink)
Old 03-28-2009, 04:43 PM
Gcrop's Avatar
Yea, I have been saving this thread for a while, just now getting around to doing it though, before the nasty heat and humidity hits.
I was asking if it would be best to hook into the white tee during the summer months and the red tee during the fall, winter and spring months.
__________________
Geoff
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
