Does anyone think having fluid (winter), then not having fluid (summer), then having fluid (winter) in the heater core could damage the core. I understand the factory setup let a same amount of fluid pass.
Was there a reason the engineer designed the system this way?
__________________ Les
2002 True Blue F350 Ext Cab 4x4 7.3 PSD SRW LB
Rhino Line; 4" BDS Lift; Bilstein Shocks; Centerline Rims; Racor Ext Fuel/Enviro Bypass Oil/Magnafine Trans Filters; 8 Autometer Cobalt Gauges; AIS; Toyo 315/75R16 ATs; Banks Monster Exhaust, Mag-Hytec Trans & Rear Diff Covers; BTS; ATS: AIH Delete; Spearco CAC; DP Tuning; DI SS Ups 30 Yr USAF Vet
I'm not sure what you mean by "not having fluid (summer)"? I've got a manual valve in the supply line to the core, but when it's shut, it just stops the flow to the core, and no coolant is drained out of the core. However, I don't think it's a good idea to leave the stagnant coolant in the core for long periods of time, so I open my valve occasionally to let fresh coolant into the core.
this is so cool. every ford i have ever had you have to have the a/c on max just to get it to blow cold. i think ford drivers are so hard core we don't need a/c
__________________
MATTHEW "The man of steel"
2000 F250 xlt 6 inch lift with 38.5"
super swamper thornbirds, DP-TUNER, k&n air filter,
ccv mod. tc lok mod, warn lockers,
ITP overboost annihilator,faze boost gauge 5" grand rock single stack
To flow fluid threw core just turn defroster on a couple of times each week. This mod is a must do, especially in Arizona. My wifes Grand Cherokee really needs this done. Thanks for the info everybody.
I run the DieselSite A/C mod and what I do is run the regular A/C setting in the mornings on my way to work and then the MAX A/C in the afternoon when I get off. That way the heater core gets a good dose of coolant every day.
__________________
Scott
'02 F-250 SC SB 7.3L 4x4 w/ 4" SuperLift, 315/75 R16 Toyo Open Country M/Ts, Bilstein 5100s - 6 position DI tuner, AFE Stage II w/Dry S Pro, HPX, 203* Billet, CCV, Sonnax, Tru-Cool, Fumoto, ZooDad, Brite-Box, 4" MagnaFlow SST, ITP OBA, A/C comfort mod!, Autometer Z series gauges, Scan Gauge II, Tough Country bumpers
I know this thread is almost 2 years old now but I would appreciate it if someone (may be nlemerise) could tell me exactly how to run the vacuum line through the firewall??? I think I've found a rubber plug at the lower right of the passengers side firewall (from inside) near the toe board.....and try as I may I can't seem to figurte out how to run the additional line through there to the new heater control valve.. Thanks for any help!!! Plus: I guess bumping this A/C mod thread to the top isn't a bad thing with summer right around the corner!
I finally got mine to go through the plug in the firewall that already had the two vacuum lines running out under the hood through it. It was a pain and took awhile to do it. I used a coat hanger too chunk through the hole and was finally able to find it under the hood.
__________________ Lee
"I'm hearing voices but all they do is complain"
