Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #166 (permalink)
Old 06-18-2007, 07:26 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
Quote:
Originally Posted by 15 and 92 Dad
2. Get a 12-16" fan and mount it on the front of your A/C condesor, You can use a manual switch or other means to energize it, while you are at idle or slow moving trafic turn it on, I droped my temp 15* while idling by doing this.
Yeah, see my post above. It was 103 outside today and my a/c was blowing out at 45. Doesnt get much better than that!
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #167 (permalink)
Old 06-18-2007, 09:22 PM
RockyMtnRanger's Avatar
RockyMtnRanger RockyMtnRanger is offline
RockyMtnRanger is starting off with a positive reputation.
Has anyone come across an electric cut off valve for this mod? I'd like to have inboard control without having to tap into the vacuum lines. I think that would be the best of both worlds, an electric manual cutoff....
Marty
__________________
Early 99 F250 7.3 4x4 Lariat LB SD - DP Tuner, CCV, V10 tranny cooler, 6637, TC lock switch, bunch of LED's, HID headlights, rear/front camera's, Pioneer AVIC-D1 GPS, Oil Guard Bypass, SS HPX, turbo back 4" SS exhaust into Heavy Parts International stacks, Autometer gauges, Zoodad, air horns, new stock chrome wheels...
  #168 (permalink)
Old 06-19-2007, 05:32 PM
CptSD CptSD is offline
CptSD is starting off with a positive reputation.
Quote:
Marty
This would be nice if you could just flip a switch installed in cab to turn it on or off...With all the knowledge of some of these guys who submit to this forum (Myself excluded) I would think that surely someone could come up with something.
__________________
2003 F-250 CC FX4 Lariat 4X4, 6.0L, SCT tuned by John Wood, AFE intake, 4" TB W/5.0" RBP SS Tip, Fumoto, 8 inch Edge lift. 37x13.50R-18 TOYO M/T's on 18X9 Centerlines, Dual Fox's w/Res. w/ Fox steering damper, singles in back...
2002 Excursion Limited 4X2, 7.3L (No mods yet!)
  #169 (permalink)
Old 06-19-2007, 05:40 PM
Well I can put something together using a servo/selenoid, but was hoping there would be something out there already. I'm all for getting things done easy
Marty
__________________
  #170 (permalink)
Old 06-20-2007, 01:45 AM
fixnair fixnair is online now
fixnair is gaining momentum as a positive member of FTE.
I am using a small 1/8" pipe three way toggle valve. Only thing protruding thru the dash is a small toggle. It switches the vacuum on and off to the water valve so I can have the water on or off.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
  #171 (permalink)
Old 06-20-2007, 10:12 AM
fixnair do you have any pictures of this. That sounds like a good alternative to an electric valve if one isn't readily available.
Marty
__________________
  #172 (permalink)
Old 06-20-2007, 11:28 AM
tamte65 tamte65 is offline
tamte65 is starting off with a positive reputation.
Marty
Well, why not use the A/C shut off valve? The installation took 20min.
And it is fully automatic, no holes etc.
__________________
Stroking South Texas
F250 -00 PSD 4x4 CC SB Lariat A/T, 151k.
  #173 (permalink)
Old 06-20-2007, 11:52 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Here's mine installed:
Joe
EDIT: I'm getting my threads confused... Meant to post this in the DieselSite... thread.
__________________
  #174 (permalink)
Old 06-20-2007, 08:16 PM
Ok maybe I'm just brain dead... the heat kicked my butt today. Could one of you explain how this is hooked up without any holes in the firewall/dash etc. I want to be able to turn the heater core water on and off at will without cutting into the vacuum line or getting under the hood.
Marty
__________________
  #175 (permalink)
Old 06-20-2007, 08:48 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE. nlemerise has a great reputation on FTE.
Marty, I don't think you can do it without putting a valve in the heater core water line (either manual or vacuum) under the hood. Of course the vacuum valve will require cutting the vacuum line behind the glovebox. In any case, it is not necessary to cut a hole in the firewall.
I drove through Las Vegas yesterday, my truck thermometer read 109 outside, and I had the blower motor set at the lowest setting and I was a little chilly .
  #176 (permalink)
Old 06-20-2007, 08:55 PM
Yep your right, I'm just lazy by nature and looking for the easy route I think I'm going to try the easiest first and just do the $2 shut off valve to make sure that I also get good results. If it works good for me, then I get busy making an electric controlled valve that allows me to do the shut off/on in gradiants.
Marty
__________________
  #177 (permalink)
Old 06-20-2007, 09:14 PM
nlemerise's Avatar
Marty
Please post any results on the electric controlled valve...the only problem with mine is that it can get too cold sometimes.
  #178 (permalink)
Old 06-20-2007, 09:27 PM
Yep that is one of my concerns also. In Colorado Springs, if you don't like the weather, just wait for 5 minutes, it'll change
Marty
__________________
  #179 (permalink)
Old 06-21-2007, 09:45 AM
Izzy351's Avatar
Getting Faster...
Marty,
Go HERE and look thread I started. There is no cutting of the stock line. You just pull the coupler from the silver canister, install the tee, and run it right through the existing grommet right next to it. Couldn't be easier...
Here's a pic:
Joe
__________________
  #180 (permalink)
Old 06-21-2007, 09:47 AM
Izzy351's Avatar
Getting Faster...
Marty
HEY!! That's what they say about the weather in Texas!!!
__________________
Tags
920001 , air , conditioning , solenoid , vacuum , wowreal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
