axle lengths
axle lengths
I've got a 9" with 28 spline axles in my 61 uni and want to put 31 spline axles in it. The 9" I recently got from an 84 f150 had larger diameter splined end that won't fit into my posi carrier. What I want to do is get 31 spline axles that will fit my carrier and go into the housing that is in the truck now. I would also like to use the brakes from the 84. Thanks Rich.
axle lengths
OK, went to the barn and measured (as close as I could by myself) some 9" F100 rearends. Here is what I came up with. 1966= 61 1/4" long, 1974= 64 1/4" long, and 1982=66 1/2" long. These measurements are outside to outside of the drums and may not be as accurate as if I had someone hold the other end. I will have to check what rearend is in my buddy's truck but he swears that it was a 67-72 housing with 73-79 31 spline axles.
axle lengths
Thanks guys FYI the rearend in my truck is 64.5" drum to drum and the 84 is 66.5"D/D but I think the housing is the same width it just has wider brakes I'm not sure because I haven't actually measured both. Also the axle shafts from the 84 are equal length and have tapered bearings. Rich
71mach351
11-02-2014 08:21 PM
aic
08-26-2012 08:26 AM
