carburetor cfm for 351m
I can get better fuel economy out of a Square bore 4v than I can out of a 2v.
The primary holes are a lot smaller than the 2v holes.
Most 2v 2150 carbs are in the 425-550 range.
My guess with your 351M it is about 450cfm
I need the info off your carb to verify it.
This question actually belongs in the fuel delivery or 335 engine series forum
I put a brand new 500 CFM Holley street avenger on my 351m a couple years ago, it worked good, but it was a touch too much carb for the motor....if i where to do it again id hold out and find a 380cfm 2bbl.....i can see the reasoning for having a 4v with smaller venturies to get better mileage, but ive never had a use for 4 barrels on trails..now in a mud drag or a long mud pit i could see needing the extra 2 barrels because you actually run wide open, but for a DD that sees mild wheeling i would definitely go back to a 2v...all that said, your either gonna need a 380CFM or 500CFM, it all depends on your motor and preferences, like i said though, i wish i would have went with a 380 in the end....
1956 f100
16
12-26-2020 08:07 PM
BiltFordTuff
03-07-2017 08:51 PM
forestgreen
10-29-2015 04:14 PM
whisler
30
03-20-2011 10:03 AM
slychicken37
13
11-20-2006 05:32 AM
1979, 351, 351m, barrel, bronco, carburetor, carburetors, cfm, ford, gas, improve, milage, modified, recommended, stock
