Computer Chips & Tuners
Locating the computer. 96 F250
Old 07-23-2006, 10:57 PM
Fallguy2004's Avatar
Fallguy2004
Fallguy2004 is offline
I need to find the computer on my 96 f250 4x4 to find out some code on the box? Anyone help me out on where to find it, and what code i'm looking for?
Old 07-24-2006, 05:15 AM
toddyw's Avatar
toddyw
toddyw is offline
The computer is located behind the driver's side kick panel. Just remove the plastic piece and there it is.
Old 07-24-2006, 04:56 PM
Troyer Performance's Avatar
Troyer Performance
Troyer Performance is offline
Former Vendor
Hi FallGuy,
If you;d like to give us a call, we can explain this in proper detail, it's really too much to get in to here.
In Brief:
the PCM is located beyond the driver's side kick panel - remove that kick panel, and then you can see the back of the PCM only - now in some cases, you may see the computer code on a small sticker there, it will be 3 letters followed by 1 number - like DUG1, BUG2, and so on.
If you cannot see a sticker there, then there is a more involved procedure we can tell you about so that you will be able to locate your vehicles code - another option is to plug in a scan device and read it's hex or strategy code - again, if you can't get to it by removing the kick panel, just give us a call and we can help you on this, as well as provide the best custom tuning in the business for these vehicles.
Good luck!
Old 07-24-2006, 08:35 PM
Fallguy2004
I will check it out. Thanks.
Old 07-25-2006, 10:30 AM
Troyer Performance
Former Vendor
You're very welcome, & good luck!
kevin g
17
02-07-2024 07:29 PM
junkyardjeff
03-25-2015 07:52 PM
96_F250_Deezal
2004 - 2008 F150
08-26-2014 08:14 PM
kabur66
6.7L Power Stroke Diesel
01-16-2011 04:05 PM
Zycot
06-22-2004 09:47 PM
Quick Reply: Locating the computer. 96 F250
