diesel cng
Old 07-23-2006, 11:34 AM
vellomike's Avatar
vellomike
vellomike is offline
diesel cng
Ok, I'm looking for a diesel cng system for my 99 ford f250 sd 7.3L. The reason I
'm interisted is I have somthing called "Free Gas" running to my house ,in other words I don't pay a natural gas bill. Has anyone seen a cng/diesel system I know I cant run 100% cng in a diesel because of its high ignition temp. but I think you can run up tp 80% cng and use the diesel fuel as a catalyst to burn the cng.I also know that propane is similar cng but hase more btus per # and can condence at a lower pressure, so I think I'll need a cng tank a regulator to handle 3600# hoses, a propane injector/controller etc.that said any help?
Old 07-23-2006, 06:27 PM
cookie88's Avatar
cookie88
cookie88 is offline
Can you run cCNG through an HEUI injector? I remember back in the day our school busses had "multi fuel" switches that let them run on #2 or propane, and I've seen CNG powered tractors....but none of those engines ran the injectors we run.
Old 07-23-2006, 06:42 PM
furball69's Avatar
furball69
furball69 is offline
You need a standard type conversion carburetor to run the fuel into the intake.
http://www.propanecarbs.com/examples.html
Old 07-24-2006, 12:13 AM
vellomike's Avatar
vellomike
Sorry by injector I ment carburetor..Isnt there some kind of fogger i can use ?
Old 07-24-2006, 07:48 AM
vellomike's Avatar
vellomike
I think the injector is realy a kinda carburetor that sits on the intake and sprays cng or propane into the air intake then the diesel fuel is needed to ignite the cng or lp, only a small amount of diesel fuel is needed as a catalyst so there must be a way to reduce the diesel injector pressure while in cng mode...right?
genegladden
1999 to 2016 Super Duty
16
02-03-2020 08:00 PM
idrivea2002golf
05-01-2016 08:59 PM
baskervi
Alternative Fuels, Hybrids & Mileage
12-31-2012 07:43 PM
gsorter
12-24-2012 03:06 PM
Quick Reply: diesel cng
