You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok, I'm looking for a diesel cng system for my 99 ford f250 sd 7.3L. The reason I
'm interisted is I have somthing called "Free Gas" running to my house ,in other words I don't pay a natural gas bill. Has anyone seen a cng/diesel system I know I cant run 100% cng in a diesel because of its high ignition temp. but I think you can run up tp 80% cng and use the diesel fuel as a catalyst to burn the cng.I also know that propane is similar cng but hase more btus per # and can condence at a lower pressure, so I think I'll need a cng tank a regulator to handle 3600# hoses, a propane injector/controller etc.that said any help?
Can you run cCNG through an HEUI injector? I remember back in the day our school busses had "multi fuel" switches that let them run on #2 or propane, and I've seen CNG powered tractors....but none of those engines ran the injectors we run.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
I think the injector is realy a kinda carburetor that sits on the intake and sprays cng or propane into the air intake then the diesel fuel is needed to ignite the cng or lp, only a small amount of diesel fuel is needed as a catalyst so there must be a way to reduce the diesel injector pressure while in cng mode...right?
