turn signal flashing fast...but both light bulbs work??
I'm chasing a turn signal problem on a 97 Fleetwood RV built on an E-350 Chassis.
The right turn signal is flashing fast like it does when a bulb is burned out, but both the front turn signal light and the rear turn signal light are fully operational.
With the turn signal off and the hazzards on, all 4 corners work like they should.
Not sure exactly how the circuit works, but once I turn the turn signal on with the hazzards on, everything continues to work, as soon as I turn the hazzards off with the turn signal still on, the right side goes back to flashing fast.
I'm coming up on a VA state inspection, will they pass me with the lights flashing fast as long as they both come on?
BTW, thanks for the reply above.
Looks like the multifunction switch is 85 bucks on ebay. Before I start buying parts, is there any way to further troubleshoot this part?
I forgot to mention that this problem is also intermittent. Some times everything just works fine, but probably 80% of the time I use it the right side blinks fast.
You can play around with the signal lever and see if it makes a difference.
I do not have anything on a 97, but in 96 you did not have to remove the steering wheel according to the link below, to change the switch.
http://www.autozone.com/servlet/UiBr...3d801783e5.jsp
Stanislaw
1997-2006 Expedition & Navigator
17
02-10-2017 12:01 AM
three.on.the.tree
21
04-21-2016 06:36 PM
1'stonraceday
11-16-2015 12:59 PM
mustange70
10-06-2015 03:28 PM
52' fordnut
07-21-2015 10:07 PM
