turn signal flashing fast...but both light bulbs work?? - Ford Truck Enthusiasts Forums
Old 07-22-2006, 06:49 PM
sigtauenus's Avatar
sigtauenus sigtauenus is offline
sigtauenus is starting off with a positive reputation.
I'm chasing a turn signal problem on a 97 Fleetwood RV built on an E-350 Chassis.
The right turn signal is flashing fast like it does when a bulb is burned out, but both the front turn signal light and the rear turn signal light are fully operational.
With the turn signal off and the hazzards on, all 4 corners work like they should.
Not sure exactly how the circuit works, but once I turn the turn signal on with the hazzards on, everything continues to work, as soon as I turn the hazzards off with the turn signal still on, the right side goes back to flashing fast.
I'm coming up on a VA state inspection, will they pass me with the lights flashing fast as long as they both come on?
Old 07-22-2006, 06:54 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
They should pass it. So long as it works and is discernable to other drivers. If everything is working, a few people have replaced the turnsignal switch, and it has fixed this problem. Ford calls it a multi-function switch, and they do give problems once in awhile.
Old 07-22-2006, 06:58 PM
sigtauenus's Avatar
Is it possible to remove the steering wheel to get to this without messing with the airbag?
Old 07-22-2006, 07:03 PM
sigtauenus's Avatar
BTW, thanks for the reply above.
Looks like the multifunction switch is 85 bucks on ebay. Before I start buying parts, is there any way to further troubleshoot this part?
I forgot to mention that this problem is also intermittent. Some times everything just works fine, but probably 80% of the time I use it the right side blinks fast.
Old 07-22-2006, 07:10 PM
Franklin2's Avatar
You can play around with the signal lever and see if it makes a difference.
I do not have anything on a 97, but in 96 you did not have to remove the steering wheel according to the link below, to change the switch.
http://www.autozone.com/servlet/UiBr...3d801783e5.jsp
Old 07-23-2006, 04:24 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Had the exact same problem with my 95 Taurus. Took a quick look at the wiring diagram & found that the only difference between flasher & turn signal circuits was in the multifunction switch.
Took about 30 minutes to swap in a new switch. Problem solved.
Old 07-23-2006, 04:30 AM
98 Navigator - problems with turn and stop lights Stanislaw 1997-2006 Expedition & Navigator 17 02-10-2017 01:01 AM
WHAT'S WRONG WITH MY HAZZARD'S/B;INKERS?! 1'stonraceday 1999 - 2003 7.3L Power Stroke Diesel 5 11-16-2015 01:59 PM
Electrical gremlins, 1990 C350/F350 mustange70 1987 - 1996 F150 & Larger F-Series Trucks 5 10-06-2015 04:28 PM
Turn signal switch problems?!? 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-21-2015 11:07 PM
05 explorer fast turn signal ascheperle Explorer, Sport Trac, Mountaineer & Aviator 3 10-07-2011 08:32 AM
Tags
blinker, blinks, f150, f250, fast, flash, flashes, flashing, ford, light, quickly, rapidly, side, signal, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
