cps
about 3 months ago the truck would not start. Found out it had someting to do with the #5 injector, problem solved. the truck ran fine until last couple of weeks. no codes at all. Did a couple of searches and thought it was the cps so I changed it. Drove the truck 2 miles down the road and it cut off. It started back up & I made it back home. Thanks in advance
Things to check and do if you have not done them. Fuel Filter change, oil & filter change, check oil level in HPOP, check fuel pressure at the Schraeder valve on the FPR, check vlave cover and under valve cover wiring/connectores/harness. (tgbeggs did a good post on ohming out the wiring; do a search). check the wiring going to the CPS. Check the Timmerman nut and wiring connection on the IPR.
