Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 07-21-2006, 08:31 AM
Bryan KF8G Bryan KF8G is offline
Garage is empty, add now
Bryan KF8G is starting off with a positive reputation.
Help!!!
I have a 90 F-150 that is hard to start and has an up and down idle between 500 and 1500 rpms. It only has 46,000 miles on it. Do I need to look and some sensor or is it some aux fuel injector. I had a similar problem with an old VW Rabbit I owned a number of years ago and it was a cold start valve gone haywire. Any suggestions?
  #2 (permalink)
Old 07-21-2006, 10:30 AM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
What engine do you have? first thing I would check for is vacumm leaks...
  #3 (permalink)
Old 07-22-2006, 03:40 AM
willyg79 willyg79 is offline
willyg79 is starting off with a positive reputation.
Have the fuel pump checked had an 88 with similar problems fuel pump was going out and eventually you could be driving down the road and it just shuts down it took me weeks to figure this one out. Bill
  #4 (permalink)
Old 07-23-2006, 02:15 AM
It's the 302 5.0 liter. Fuel pump huh? Thats interesting. I suppose it's in the fuel tank like a Mustang. It's going to a local mechanic Monday. The Ford garage thouroughly screwed it up the last time they "Fixed" it so we're going to someone we trust a lot more. I'll tell him to look at that.
  #5 (permalink)
Old 08-16-2006, 12:52 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain has a good reputation on FTE.Freightrain has a good reputation on FTE.
I'd say the IAC motor. Idle air control. Little 1 1/2" round can that mounts right there at the throttle blades. It opens/closes to control idle. MIght be screwed up, stuck open? Got some soot in it maybe? Two small bolts hold it on, take it off and spray some carb cleaner thru it. Make sure it's clean inside. Put it back on and try it? Better? NOT? Might be faulty all together?
__________________
*signature delete option*
  #6 (permalink)
Old 08-17-2006, 09:22 AM
Actually it came out of the shop last week with a new map sensor. But I'm also gonna check the suggestions I've recieved as well. It's running very well but since the Ford garage fixed a fuel injector last year, it went from 16 to 8 mpg. So theres still more going on. More to come I guess....
  #7 (permalink)
Old 08-18-2006, 04:41 PM
grampztoyz351 grampztoyz351 is offline
grampztoyz351 is starting off with a positive reputation.
I'd agree with Freightrain on the IAC.
  #8 (permalink)
Old 08-19-2006, 01:17 PM
It does idle a bit funny when it's cold. I'll make sure to take it apart and clean it. Sounds like a good suggestion.
  #9 (permalink)
Old 08-21-2006, 02:52 PM
Shiftoholic
Shoot, Bryan...didn't realize you're in Akron. I'm in Canton, work in Barberton.
Let me know if I can help in any manner....since I'm close.
__________________
  #10 (permalink)
Old 08-22-2006, 10:17 PM
Really? Wow. I grew up in Wadsworth and actually live in Kenmore. Yea, I'll have to look you up sometime. You'll like my truck. It's not your typical Ohio truck. Still pretty clean. Do you ever go to Winks in Barberton on Friday or Saturday night? Maybe we could meet there sometime. My 1972 Chevy C-20 should be out of the tranny shop next Tuesday and I want to take it to Winks. That one only has 29,000 miles.
  #11 (permalink)
Old 08-23-2006, 09:36 AM
Shiftoholic
Ya, I hit Wink's a couple times a year or so. If you've been there, you might recognize my black 64 galaxie with 390/6-71 huffer/4 spd, or my 69 blue/white F100 shortbed with 428/quads/4 spd.
Do ya ever eat at Hodges? It's my lunch hangout at noon 'bout every weekday.
__________________
  #12 (permalink)
Old 08-23-2006, 09:49 PM
Yea, I think I remember both of them. It's been a bit since I've been to Winks. My 72 Chevy truck is orange/red and the only one that color in the area so it's pretty distinctive itself. I used to go every weekend until it broke down. But that was like 3 years ago. Just haven't had the time to mess with it. But it will be back on the road next Tuesday. We'll have to hook up sometime at Winks and I'll drive the Ford. I spent a whole day on it a couple of weekends ago so it's pretty clean right now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
