Lowering rear suspension
Old 04-06-2011, 05:13 PM
David1958's Avatar
David1958
David1958 is offline
Does anybody out there have hands on experience lowering their rear suspension on their van. I have a 1989 E-250 and would like to lower the rear 2". I read somewhere that the shackles made for the pick-ups work for the vans as well so I purchased a set of Belltech 6425 lowering shackles. Well, they don't fit and now I was wondering if anyone else has had any success lowering their rear suspension using the shackle method. I don't want to remove a leaf or otherwise modify the springs, I really would like to be able to accomplish this with the shackles. It seems easy enough I just haven't been able to find a shackle that fits. I would appreciate any suggestions? Thanks.
Old 04-08-2011, 05:26 PM
SilverE350's Avatar
SilverE350
SilverE350 is offline
Most people are a little obsessed with raising the front of the van by 2" so they can fit larger tires under it, and here you are wanting to lower yours. I would say to go to your local spring shop and ask them. The stock shackles already point up so you might run into a clearance issue.
Old 08-22-2011, 01:05 AM
james843's Avatar
james843
james843 is offline
go to the junk yard and get a stock set and thke them to a welding shop and have them extend them 2"
Old 08-22-2011, 05:31 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
Just being nosey but why lower the suspension?
Old 08-22-2011, 05:54 AM
james843's Avatar
james843
james843 is offline
4 the look
Old 08-22-2011, 09:53 AM
JWA's Avatar
JWA
JWA is offline
Originally Posted by james843
4 the look
Oh okay!
I like the new ride height only because it lowers the cargo deck and would be easier to enter and exit. Of course ground clearance would be an issue---have to avoid loose coins laying on the road!!
Old 08-24-2011, 07:52 PM
David1958's Avatar
David1958
I like the level look. With the 250's and the 350's the heavy springs usually lift the back end a couple inches and I don't care for the look. Also by lowering the rear I am able to park the vehicle in my garage without letting air out of the rear tires.
Old 08-25-2011, 10:38 AM
redtanrt10's Avatar
redtanrt10
redtanrt10 is offline
James, looks real sharp! How is the ride and handling compared to stock? Mike
BEN WHEELAN
02-27-2017 03:03 PM
Trev5402
2004 - 2008 F150
07-18-2016 10:27 AM
Nothing Special
20
06-13-2015 08:01 PM
brutus67
04-29-2014 02:24 PM
OldWoodsDiesel
10-22-2012 07:45 AM
Quick Reply: Lowering rear suspension
