Auto Lamp Sensor Problems
I have a '97 F150 Lariat and the lights seem to come on prematurely. I have not been able to find the sensor. I understand that there is a senor build into the blinking light on the dash. On my truck, I have a blinking 'THEFT' light when the alarm is activated. Is the sensor behind the tach or some other place.
What's involved in changing the sensor, or is there an easier fix. Thanks, Mike
Hi Mike and welcome to the forum
I've never had much to do with the autolamps on one of these trucks and the shop manual seems to have not much on them either. If I remember right if you pull up the football shaped cover on the top of the passenger's side of the dash there is a module there with the ambient light sensor built into it. I can't remember for sure what it's like on an F-150 but on most other Fords it's a little dome shaped sensor on the top middle of the dash.
Hopefully someone else will come along with a better memory than me
Originally Posted by texski
Thanks guys for the quick response. I suspected that it might be under the football-shaped cover. After 10 years, I am hoping that all I have to do is wipe the dust off. Now, how do I get the cover off. I hate to go pulling in the wrong place and break it. Thanks again, Mike
It is held in place by several clips. Slide a putty knife under the edge and lift gently.
Thanks KRM. I'll give it a shot. I replaced the DPFE sensor today and it is running right. On to my next project . . . change the trans oil after 131K? What say you? Mike
Just a response about the autolamp sensor. Instead of removing the football shaped cover, I blew compressed air into the slotted holes in the center. After almost 10 years, I figured there was some dust that had settled. I guess that I was right because it is more responsive now. Thanks again, Mike
dan_s_johnson
Electrical Systems/Wiring
07-17-2014 07:03 PM
1995droptopz
1999 to 2016 Super Duty
07-15-2011 09:48 AM
crazy4campin
04-09-2008 10:51 PM
