I have a 90 7.3 and I am going to change the return lines on it. I have heard that bio diesel ruins rubber so what should I use to replace these lines?
__________________
1990 F250 supercab 4x4 5spd 7.3 turbo 4.10 gears
DPS turbo injector pump with Holley red BIG difference!
LUK clutch and now with working A/C, turning out to be a nice truck!
I have heard that bio diesel only degrades natural rubber. I would assume that fuel lines are made of a synthetic rubber, so I don't feel it should be an issue. But that's just me.
Buna-n is a synthetic rubber and will soften just like natural rubber. You need to use Viton fuel lines to be safe.
FABMANDELUX.
__________________
Oregon Chapter Leader: To join the Oregon Chapter, click HERE My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
__________________
This is something I'd like to know about then, becuase I would like to try WVO next summer (just don't have time this year, and the vehicle doesn't have many places to go). I have mostly metal lines still, but some lengths between components I have replaced with rubber because the metal lines could not stand the vibrations. It was recommended by the local store to use transmission line, so that is what they sold me, and so far, for normal diesel, it has worked just fine. Will WVO degrade this stuff? I'm sorry if you've already given your answer...I'm just not familiar with what "Buna-n" is.
Addition: I just looked "Buna-n" up and apparently this type of rubber degrades with highly oxidized fuels. I would assume that transmission lines are made of this?
Yes, and it isn't good with biodiesel.
FABMANDELUX.
__________________
__________________
__________________
I am having trouble finding viton the auto parts store cant even order it
__________________
I went to my local auto cool shop and he had Viton "O" rings. They were green in color. I think they are used in the new R-134A AC units.
FABMANDELUX.
__________________
You can get viton o rings from any hydraulic repair shop. They use them when extreme temp and pressure are to be used. They are usually brown in color.
bterry,
Just got threw reading Planet Drives recomendations for WVO fuel lines, they recomend Gates XL fuel lines for there conversions, I am running Gates at this time.
FYI, I am up in the Cooperstown area, I plan on comming down to the Giant scale Model Airplane event next weekend at the Chenango Bridge Airfield. I plan on camping there Fri. and Sat. evening.
I have 2500+ miles on WVO at this time.
Flyboyd8 :-)
__________________
Ken, Central NY
Mighty Pre-94, (93) F250, 2wd, 7.3 N/A, E4OD, 3.55, ext. cab, 200K+
