Rubber lines?
I searched the Gates site, and can't find anything on XL hoses, just belts. I'll bet those Gates hoses aren't rubber.
No kidding! Have you seen this post?
https://www.ford-trucks.com/forums/5...th-2006-a.html
You should really consider stoping by. The NY Chapter Leader (Ronin007) plans to be there, and Ken (FTE Owner) may be sending a couple of goodies for us to share.
Originally Posted by flyboyd8
FYI, I am up in the Cooperstown area, I plan on comming down to the Giant scale Model Airplane event next weekend at the Chenango Bridge Airfield. I plan on camping there Fri. and Sat. evening.
bterry,
I searched the Gates site and can't find anything on XL hoses, just belts. I'll bet they are not rubber if recommended for WVO.
The Bus Boy, asked if when he uses WVO,will rubber lines be OK,as I read the post after his guestion,all remarks were still for BioDiesel.
Please clarify, If I and Bus Boy are going to run "WVO" ,Will the rubber fuel lines be OK.
Flyboyd8
Flyboyd8
I use Aeroquip Socketless hose and fittings made by Eaton. They are press lock and need no clamps. Cost a bunch more but I never have to worry about air leaks.
We have no special preparations yet for BD...and I want to know if I can just start using it. I am aware of this need to change out the fuel filters in the beginning. How about neoprene seals? Will they be affected negatively by B99/B100?
Also, what about a type of fuel injector- my auto shop told me I need to get another kind for BD & I didn't know what he was talking about.
Truck we have: '96 7.3 PSD F250
Thanks-
Thanks-
Thanks-
Thanks-
FABMANDELUX.
Thanks, further question...
Hi, thank you so much for your prompt reply. I am SUPER excited about the prospect of using biodiesel, As you can imagine, since I am not alone (my husband and I share the truck, and will be taking it to Mexico with us when we move there next week), and it is mainly me who is driving this interest in BD, I am very concerned about any potential issues that might arise and want to be informed before we make the switch. We have a couple local pumps and I'd like to get started asap.
Don't get me wrong, my husband is very keen on the idea of saving $$ by even being able to "brew our own" down there, or do the WVO extra tank thing when we're feeling a little more confident and experienced...but we don't have a lot of spare cash to mess around with any big repairs if we do it poorly. So I'd appreciate any mechanical tips you can share on beginning to use BD.
I should mention that we just bought the truck earlier this month, and we just had to replace the fuel pump and some o-rings and seals b/c it was leaking diesel and it had been pooling in the (valley?) below the engine.
After 1994 ford started using synthetic fuel lines in all their diesels, so you should have no problems with your truck. One thing you can do, is install a cheap "see-through" filter inline before your main fuel filter, so you can see if any "crud" is in your fuel. Keep a spare in the glove box in case it starts to look nasty.
Try reading here first, it is a great site and will explain much to you and hubby: http://www.biodieselcommunity.org
Good luck!
FABMANDELUX.
Good luck!
FABMANDELUX.
Pappys53
05-12-2011 09:28 PM
vancouver island
13
11-10-2009 05:45 PM
gearhead351
12-05-2007 02:37 PM
