4.6L spark plug wiring diagram - Ford Truck Enthusiasts Forums
Old 07-20-2006, 02:53 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
heya,
I searched and searched, this forum and through Google, but i gue there are too many hits on spark, plug, wire, and diagram - because through all the info I just couldn't find a wiring diagram
I need a 1999 (1997/1998 will do) spark wire diagram just to make sure a buddy didn't make my missing problem worse.
Truck is trying to cool down so i can work on it today, or I'd go pick up a manual.
Anyone have a quick link to one?
Thanks
Old 07-20-2006, 06:38 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
If you clean the coil packs and look carefully there should be numbers beside the plug wire terminals indicating which wire goes where.
Old 07-20-2006, 07:59 PM
hang10's Avatar
hang10 hang10 is offline
hang10 is starting off with a positive reputation.
If you have a library close, copy that page from the Chilton manual. If you still haven't been able to locate it, I can copy a page and email it to you.
Old 07-20-2006, 08:03 PM
Thanks guys! Racerguy pointed out what was right in front of my face all along.
Damn, I feel stupid.
I put MSD four-tower coils on it (which do not have the wiring order on them, so I'm probably going to keep one coil around as it has the total wiring code right on it).
'98 2.5 spark plug wires merkswitch Ranger & B-Series 3 11-03-2015 01:24 AM
9mm Ford Racing Spark Plug Wire Set Tim Hodgson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-11-2015 01:39 PM
1995 crew cab F350 door lock wiring diagram? akakiller 1987 - 1996 F150 & Larger F-Series Trucks 0 03-14-2012 12:18 AM
spark plug wiring diagram 98 e150 marvel150 1968-2013 Full Size Vans 1 01-08-2011 06:06 PM
Flathead 6 226 Spark plug wire diagram, Help jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-20-2010 12:01 PM
Tags
1997, 1998, 1999, 2001, 46, 46l, diagram, f150, ford, plug, spark, sparkplug, wire, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
