Rear tire help please
What aspect ratio are they??? the tire should read 285/?? R 16. The first # is the total width of the tire from bead to bead, the second # is the % of side wall the tire has. For instance a 285/75r16 tire will measure 285mm from bead to bead, take that x the aspect ratio (75%) and you have the sidewall height (213mm)
Hope this helps
Duane
Hope this helps
Duane
Your 97 two wheel drive should ve the same as my 95 two wheel drive.
You mentioned rear tires and a set. Are you looking at 285s for just the rear or for front and back? You have waaaaaaay more than enough room for them on the rear.
I have 285/75 R 16 LT Cooper Discoverer ATR on mine with no issues except the back inside sidewall of the front tires will contact the radius arm in a full lock turn. It has not been an issue, they just barely touch and have not damaged the tires in the 14,000 or so miles I have had them on. They are VERY close to the bumper as you turn but no interferance so far.
Dave / Believer45
Dave / Believer45
