Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 07-18-2006, 09:51 PM
R L R L is offline
Garage is empty, add now
R L is starting off with a positive reputation.
Gas Guage
Ive got a 06 F350 PSD and when I fill the tank the guage reads empty for about 50 miles then it comes back up to full. Took it to the dealer and they said I would have to bring it on a empty tank so they could fill it up and see the problem. Anyone else had this problem?
  #2 (permalink)
Old 07-18-2006, 10:51 PM
donjamer's Avatar
donjamer donjamer is online now
2006 Ford F-350
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Do you leave the key on when you fill up? I believe this is normal. Mine does the same only when I leave the key on.
__________________
Don #3 SlackMaster
Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here
Currently own:
2006 F350 Lariat CC Super Duty, 6.0 L Diesel
FTE Fraternity OF Blue Max
  #3 (permalink)
Old 07-19-2006, 04:44 PM
firesoutmatt's Avatar
firesoutmatt firesoutmatt is offline
firesoutmatt is starting off with a positive reputation.
Don is correct . Key on or left running while fueling will screw up the reading for awhile.
__________________
05 F-250 CC SRW LB 4x4 6.0 Tow Command Lariat Remote Start All Stock 01 Alfa 40' Toyhouse for all the toys.
I'm doing my part to reduce our dependency on foreign oil and clean up the environment; my truck runs on 100% biodiesel made from soybean oil grown by U.S. farmers. What are you doing?
  #4 (permalink)
Old 07-19-2006, 05:39 PM
triplethreat triplethreat is offline
triplethreat is starting off with a positive reputation.
You could listen to these guys or take it to the dealer on empty so they can fill your tank for free (warranty)
__________________
'04 F-250 CC Lariat white/silver 4X2 PSD, auto, SWB 3.73 lsd, Reverse sensors, captains sliding rear, leonard cap, DeeZee Bedmat/// '96 F-150 SC EB SWB Blue/Tan 5 Spd
  #5 (permalink)
Old 07-19-2006, 05:49 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
2003 Ford F-350
Maxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant future
That is funny........and he is right......
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
John
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L
Kony 2012
  #6 (permalink)
Old 07-19-2006, 07:07 PM
Quote:
Or they will give it to the lot guy(gal) and he will fill it with gasoline.
__________________
  #7 (permalink)
Old 07-19-2006, 10:12 PM
Hayapower!'s Avatar
Hayapower! Hayapower! is offline
Hayapower! is starting off with a positive reputation.
Fuel Gauge
The instrument cluster receives the fuel level signal from the fuel level sensor, part of the fuel tank unit. The fuel level sensor measures variable resistance in the fuel tank depending on the current fuel level. When the fuel level is low, the resistance in the unit is low (15 ohms ą 2 ohms). When the fuel level is high, the resistance in the unit is high (160 ohms ą 4 ohms).
The instrument cluster uses 4 different operating modes to calculate the fuel level:
anti-slosh (default mode)
key OFF fueling
key ON fueling
recovery
After a fuel fill up, the time for the fuel gauge to move from empty (E) to full (F) ranges from 2 seconds to 55 minutes depending on which operating mode the fuel gauge is in.
The default fuel gauge mode is called the anti-slosh mode. To prevent fuel gauge changes from fuel slosh (gauge instability due to changes in fuel sender readings caused by fuel moving around in the tank), the fuel gauge takes approximately 55 minutes to go from full (F) to empty (E).
The key OFF fueling mode (2 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The key must be in the OFF position when refueling the vehicle.
At least 15 percent of the vehicle's fuel capacity must be added to the fuel tank.
The instrument cluster must receive a valid key ON fuel sender reading within 1 second of the key being put into the RUN position. The key ON sample readings are considered valid if the fuel sender reading is between 15 ohms ą 2 ohms and 160 ohms ą 4 ohms. If these conditions are not met, the fuel gauge stays in the anti-slosh mode, which results in a slow to read full (F) event.
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in park (P) (automatic transmissions), or the parking brake applied (manual transmissions).
The key is in the RUN position.
In key ON fueling mode, a 30 second timer activates after the transmission is put into the park (P) position (automatic transmissions) or when the parking brake is applied (manual transmissions). When the 30 second time has elapsed and at least 15 percent of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of park (P) or the parking brake is released, the fuel gauge strategy reverts to the anti-slosh mode. This mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
Recovery mode is incorporated into the instrument cluster strategy to recover from a missing fuel level message during a refueling event. Missing fuel level messages result from intermittent opens in the fuel sender or its circuits. Recovery mode (empty [E] to full [F] approximately 20 minutes) is initiated when the following 2 conditions are met:
The instrument cluster is in the anti-slosh (default) mode.
The actual fuel level in the tank is greater than what is being displayed by the fuel gauge.
__________________
05 F250 XLT, 6.0, Torqueshift, 4x4, FX4, Crew Cab, Arizona Beige, Captains/Tan Interior, Brake controller
1969 Firebird Trans AM
03 Suzuki GSX1300R Hayabusa
  #8 (permalink)
Old 07-20-2006, 05:36 PM
That should be put on a sticky. Answers alot of questions . I never knew why it did it just that it did. Thanks Haya
__________________
  #9 (permalink)
Old 07-20-2006, 08:08 PM
rblomquist rblomquist is offline
rblomquist is starting off with a positive reputation.
That is a lot to digest! I always fueled my Dodge running in order to baby the turbo as much as possible. It's not good to pull off the freeway while pulling 10,000+lbs in 100 degree+ heat and immediately shut her down just for fuel.
The 1 time I fueled the SD with the truck running I obviously got the VERY slow to react fuel gague, figured it wasn't good for it and stopped fueling with engine on. That really annoyed me but it sounds like it should have no adverse effect other than just taking some time to return to an accurate reading.
__________________
05 F-350 PSD 4x4 SRW LB, 6-Speed, Never 'Flashed'
Retired Air Force
Haul a 32' 5ver Around
Former owner of a Tag-Toybox
  #10 (permalink)
Old 07-20-2006, 09:21 PM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
2011 Ford F-350
Kep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant future
Quote:
I agree. Nice to see you posting again Hayapower, great info on fueling up the Super Duty.
__________________
Russ
'11 F350 DRW Lariat 4x4 6.7, Bilstein 5100 shocks, Highway Products tool box, Duraflaps, no HPFP failure worries
Built 2/2/2011
'07 Weekend Warrior FSC 2800
'05 F250 Lariat CCSB 4X4 6.0 - Sold 4/26/11 w/96,500 miles
  #11 (permalink)
Old 07-20-2006, 09:26 PM
kw5413's Avatar
kw5413 kw5413 is offline
Fortune Favors The Brave
2010 Lincoln MKT
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
It has been added to the 6.0 Tech Folder - Thanks Hayapower!
__________________
"You're doing a lot of choppin', but no chips are flyin'." - Foghorn Leghorn
"I am not afraid of death. It is the process of dying that bothers me."
Book of kw5413, Chapter 2012 Verse 05:17
  #12 (permalink)
Old 07-20-2006, 09:32 PM
wrangler76 wrangler76 is offline
wrangler76 is starting off with a positive reputation.
I've never had any inaccurate appearing fuel guage readings in my '04 and I have fueled up running, off, on slow pumps and the quick fill pumps... That's some interesting tech info! Thanks....
__________________
Adam
Carson, WA
"Meller Yeller" - '79 F-350 4x4 Supercab, Built 356 series
'04 F-250 4x4 Supercab, 6.0 PSD
  #13 (permalink)
Old 09-20-2006, 03:51 PM
concordpete concordpete is offline
concordpete is starting off with a positive reputation.
Have had check engine lite come on 3 or 4 times when I topped off tank, trying to really filler up. Sometimes the check engine light goes out like on the next tank full or I've taken to the dealer(under warranty)and they reset it? The fuel gauge always acts normal. any comments?
  #14 (permalink)
Old 01-26-2007, 10:54 AM
myjaycopuller myjaycopuller is offline
myjaycopuller is starting off with a positive reputation.
Just recently started having fuel gauge problems in my 04
Just in recent months I've filled up my 04 from near the 1/4 mark with the key off and when restarting the gauge goes to max empty and the warning light and chime come on. After a few momments the gauge goes back to where it was prior to refueling (1/4). It has taken some period of time (minutes to an hour) or number of engine restarts to finally get to the full mark. This has occurred 3-4 times. I haven't yet been to the dealer and probably wont after reading this thread.
  #15 (permalink)
Old 01-26-2007, 01:08 PM
kw5413's Avatar
2010 Lincoln MKT
Could be this:
Check Engine Light on with P0460 Fuel Level Sensor Code:
This may be caused by a miscommunication of fuel level ststus between the instrument cluster and engine computer. This code is set when the engine computer does not see the fuel level dropping it expects. It may be caused by customer-installed items, such as a remote start system that does not power the dash when activated, an over-sized fuel tank or in-bed fuel tank. If these conditions do not exsist, the engine computer should be reprogrammed using WDS/IDS version 43.4 or higher. This condition can also be caused by fueling with the engine running, parking on an angle, or driving up a long grade. In some cases the fuel level sender may be faulty, or have a sulfur build up on the sender and have code P463(use Chevron Techron Plus Concentrate to correct). TSB 06-13-11
__________________
Tags
2006, 2007, 434, 60, check, diesel, f350, ford, fuel, guage, ingine, level, light, p0460, sender, sensor, superduty, version, wdsids
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
