tranny cooler
tranny cooler
Any recommendations on the best aftermarket tranny cooler? It's for a 2001 F250 7.3 diesel. Would like to be able to mount it in the stock position without fabricating any new brackets. Do you know how much this will reduce tranny temp? I'm in Phoenix and 110-114 degree days are too common in the summer.
Thx
Thx
Does this truck see a lot of offroad use or is it just a pavement pounder? If you aren't taking it off road you should look into a deep sump tranny pan. They make them with cooling tubes in the face, this gives more surface area to the air to cool the fluid. Also, the increased amount of fluid will lower temps as well. As an added bonus these pans are stronger than the stamped stock piece which will brace the housing and reduce the amount of twisting in the tranny/valve body which will improve tranny life. The coolers I have seen reduce the temp of the fluid quite a bit which is important to protect and prolong the tranny life.
wahlturfcare
06-20-2016 03:09 PM
Ezalycasaid
05-27-2016 08:27 PM
KrautBurner
08-13-2011 12:58 PM
