More tranny temp. ??
I have an Edge Evolution Programmer that also monitors TFT. I was getting a reading of 200* pulling a 10,000# trailer so I installed a Tru-cool cooler and it reads 170 in Hellsville's heat of 115* with stop & go traffic but without a trailer. I won't know 'till camping weather in the Fall what working Temps are but I expect a significant drop. I would think the Edge is reading the temp off the computer so can I also figure it's taken from a point of highest temperature?
Thanks..
Thanks..
yea the computer monitors the tranny temp. In fact when cold it won't allow the converter to lock up until the tranny reaches a preset temp. It's not that high but it's there.
Not really sure of where it's taking it's reading but I'm guessing it's inside the valve body where the rest of the electronics are.
Thanks..
Thanks..
Originally Posted by DaBigTow
TFT is picked up from a sensor mounted on the solenoid bank by the valve body. I've seen mine as high as 230 pulling 8k trailer up a 7100ft pass, with twin 25k coolers.
Personaly, I just grabbed a big mother of a A/c condensor which is 2/3rds the size of my rad and over an inch thick, if the day is only 22 celcius, I've run as low as 130-140d empty down the highway. Same breath, I've hit 195 on the flats tugging 5 cords of wet fire wood.
But to answer your question................170 of city driving is not bad, its stop and go traffic, you dont have that airflow through the cooler like pounding down the highway
