460 gas mileage
#62
#64
Get rid of that emissions Holley carb and replace it with a Holley 1850 or any other 600 CFM vacuum secondary carb that meters fuel rather than air. Change the power valve to a 85 or if you are towing with it too, a dual stage power valve. Get a distributor with a shorter advance curve, 10° preferred but 13° or 15° will work. Get an adjustable vacuum advance can for the dist. Total mechanical advance @ 36°. A dual exhaust system (2 1/4 or 2 1/2") or a single exhaust with at least a 3" pipe but 4" is preferred. And the biggest help is to slow down. I found that with my 1984 F250XLT Supercab, Superduty, 460, C6. 4.10 and stock tires had the mpg drop like hell after 58 mph, so 55 is a good place to stay. I also found that the cruise control did as good as I could using my foot.
#66
That just means he used the "SEARCH" button!
I had a 1977 F250 2wd,460,C6,Dana 61 with 3.07 gears and got consistant 14mpg....but I used a Quadrajet instead of the holley,edelbrock,or motorcraft 4350.... and that truck drove sooo smooth and passed emissions here in California w/o problem.
fordf100amc
13
01-26-2012 04:31 PM
datsun147
04-25-2011 12:41 PM
green_lightening
07-28-2010 08:36 AM
