460 gas mileage
Old 07-21-2006, 12:16 AM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
Originally Posted by TooManyTrucks
I see you guys have the older carbed trucks. I am looking at a 97 EFi F250 HD SuperCab with the 460 and 5speed manual. I need something that pulls. It isn't a daily driver. I have a 90 f150 right now that gets 8-10 mpg under load (5,000lb towed) and can't get out of it's own way. How are the newer (if you consider 9 years old newer) EFI 460 Trucks like this on the mpg tuned up? I'm guessing 12-14 highway unloaded with a light foot and a tail wind. Am I off base?
You might try a search in this thread to see if there has been any post about 460 EFI
  #32
Old 07-21-2006, 12:50 AM
turbo2256d's Avatar
turbo2256d
turbo2256d is offline
Best mods I know of is replacing the exhaust cat back and adding any 5.0 TB. After that your better off with older heads and making up your own injection system or aftermarket TBI.
  #33
Old 07-21-2006, 09:22 AM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Originally Posted by littleme13
bolt a block to the back of the gas peddal so you cant go over a 1/4 throttle is the best advice...lol of course if you need more it could be a problem. your driving habbits will effect everything the most. my 85 i can get between 10-12 mpg highway if i dont try and drive 80mph. headers is a good place to start. a good clean air filter will help. recurving the distibutor ive heard helps a lot. good plugs and wires also. basicall open the exhust as much as you can and a really good tune up.
hope this helps
tony
I'm glad to see great sense of humor. And your right.
He could keep it parked to and that will improve the mileage. (LOL)
  #34
Old 07-24-2006, 06:45 AM
mpmccarthy's Avatar
mpmccarthy
mpmccarthy is offline
Intuitively we all know why we want to improve gas mileage. Save money, right?
Well, if I get 6MPG on my 460 and I improve the MPGs by a mear 5% to 6.3MPG, and gas is $2.859 per gallon, I save about $22.69 for every 1000 miles I drive.
So, if you only drive 1000 miles a year some of the suggested improvements are not economically justifiable, but if you drive it 30,000 miles a year (like I do) then your savings would be about $680 per year for a meager 5% increase in MPGs.
If I could improve my gas mileage from 6MPG to 7MPG I would save a little over $2,000 per year in fuel costs. If I spent $500 to get that extra 1MPG it would pay for itself in 3 months. Not a bad deal.
Please keep discussing this issue and suggesting any and all ideas for improving gas mileage on a 460. It doesn't cost me much to read the threads and it could save me a ton of money.
  #35
Old 07-24-2006, 08:20 AM
SuperSnake's Avatar
SuperSnake
Well one of the first thing I did was to go to a smaller carb from the factory holley I had on mine.I went to a Edelbrock 600 Cfm. Now I plan to change my gas tanks I have dual tanks but will go to a single rear tank by getting a 38 gallon tank from LMC. After that I can add headers with true dual exhaust. Also I plan on a AOD swap from my C6 which with all that done and my current gear ratio(3.55) I hope to get a solid 10 MPG on a ragular basis. But I haven't heard anyone talk about the grade of gas they are running?
  #36
Old 07-24-2006, 11:52 AM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
Good math on the "not worth it if you drive 1,000 miles a year".
With the price of gas so much higher than it has been though, the break-even is faster than it used to be.
I've got the same truck... 460/5-speed/4wd/extended cab/4:10 gears. I got 11 mpg driving across Kansas with it... at 80 - 85 mph. I was getting closer to 14 though when I drove at 65mph, so I think your 12-14 should be realistic, provided:
-You are talking all highway. My above mpgs were entrance ramp to exit ramp, gas station, repeat. No traffic, no idling, no redlights.
-You aren't trying to make it from Denver to Pittsburgh in 28 hours (I slept for 5 hours and still avg'd better than 60!).
-The truck is empty. Weight kills mpg
While these trucks will really GO with a 460, they'll go much further with a light foot. If the tach clears 2200rpms you're wasting fuel.
  #37
Old 07-24-2006, 01:47 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Since when did the stock 460 come with other than a 600CFM carb? Unless you had one of them Motorcraft things and I'm not sure they were bigger than 600.
  #38
Old 07-24-2006, 01:51 PM
SuperSnake's Avatar
SuperSnake
Mine didn't come with a 600.I put a Edelbrock 600 on mine cause every rebuilt factory motorcraft holley's leak.Even the ones from Tomco were bad after going through 3 of them I went and bought a Edelbrock and haven't had a problem since.
  #39
Old 07-24-2006, 02:16 PM
Bear 45/70's Avatar
Bear 45/70
The stock Holley's (or if you prefer Motorcraft Holleys. Made for Ford/Motorcraft by Holley) were all 600CFM carbs. If it was something else then someone changed it and it wasn't a Motorcraft Holley. If a Holley carb leaks after a rebuilt it is poor workmanship and not the carbs fault. Besides why buy a carb rebuilt by someone who doesn't give a rats a$$ how you truck runs? Do it yourself and have it done right. If you can swap carbs, you can rebuild a Holley, which can't be said for the Edelbrock; which is actually a Carter carb from back in the 50s and 60s, so don't kid yourself into thinking it is a new carb design, He!! the Hemis back in the 60s came with a pair of them and they were noted for the carb fires.
  #40
Old 07-24-2006, 02:26 PM
SuperSnake's Avatar
SuperSnake
I never said it was a new design but a new carb.For what I use my truck for it works fine.
  #41
Old 07-25-2006, 11:12 AM
gpfarrell's Avatar
gpfarrell
I have an Edelbrock carb on my Mustang and love it.
What that has to do with getting more mpg's out of a truck with fuel injection is beyond me though, and well off the topic of this gentleman's question.
  #42
Old 07-25-2006, 11:19 AM
SuperSnake's Avatar
SuperSnake
Well in the original post he never said if it was efi or carb'ed it wasn't until page 2 that he let everyone know it was efi.
  #43
Old 07-25-2006, 04:24 PM
turbo2256d's Avatar
turbo2256d
Huummm I put a bigger carb on mine and got better economy and mo ppower.
  #44
Old 07-25-2006, 04:26 PM
SuperSnake's Avatar
SuperSnake
What did you put on?
  #45
Old 07-25-2006, 08:28 PM
turbo2256d's Avatar
turbo2256d
Holley 750 mechanical secondarys with a Pro Form body. Had the carb from before. I ran a 600 and a 650 they just didnt work out towing my 14000lbs boat. Economy sucked with them too. I would recomend a vacuum secondary 750 ovr the mechanical. Being frugal I just grabbed one off my shelf. Cant say it would be best for your combo + it wll have ported heads before winter I hope. Got to finish this hipo Nailhead moter and sell it first.
Quick Reply: 460 gas mileage
